For Sale 1971 fj40 Colorado
Gunnison, Colorado
As much as i hate to do it im putting my 40 up for sale. The wife says one vehicle must go and i habent had luck selling the other 2. I'm located in Gunnison, Colorado. One thing that has happened since writing the ad is the speedo quit working. It needs a new gear in the tranny. I might have this done time permitting. I can provide more detail and pics upon request. Ive tried to include photos of the rust areas. Mud asking price $8500, may consider partial trade.
On to the details:
Tastestefully modified to enhance driveability. heres a list of what I can remember that has been done to it. I have paperwork/reciepts for most, if not all, work done over the last 16 or more years. I also believe this vehicle is smog exempt but you would have to confirm.
Saginaw power steering kit/ brand new pump
Front end recently rebuilt along with fj60 disc brake conversion
Aftermarket heat riser
Fog lights
Brand new oem radiator/cooling system gone through
New oil pressure sending unit
New speedometer cable and speedo rebuild
Security box mounted under drivers seat
Has 33x12.50's TSL Thornbirds on aftermarket rims
New tie rod ends and tie rod
lift and steering stabilizer with rancho 9000 adjustable stocks
Engine was upgraded to the 2f engine, replaced June 2011 with remanufactured engine with about 70k miles on it, runs great, Engine has about 90k miles now.
Transmission/tcase rebuilt 5-10k miles before reman engine was installed
MAF 6-1 headers, high flow muffler and exhaust
weber carb, converted to manual choke as it worked better where I live, tuned for the altitude and runs great
upgraded coil and distributor (Mallory)
Center force clutch
heavy duty industrial battery
Sony xplod stereo with iPod, USB, aux hookups with remote mounted under middle seat
Aftermarket volt meter (since they didn't come stock)
new alternator
New spark plugs
New front window gaskets
New belts
New fuel pump
new oil pump/oil pan gasket
new clutch slave cylinder
new brake master cylinder
Rear drum brake cylinders rebuilt
New front heater core
Aisin locking hubs from fj60
warn 9000 winch
Floor shift conversion
chains
hard top/doors and bikini top
rear accessory gate, spare tire and 2 jerry can mounts with water and gas cans included
custom rear bumper toolbox with hitch
New heater blower motor resistor
Heavy duty skid plate
Con-ferr shackles
Front U-bolt skid plates
Fire extinguisher
heavy duty front bumper with hi-lift jack mount and warn winch mounted (jack not included)
Desmogged
New transfer case rear output seal
Various new seals and gaskets
im missing a ton more, lots of odds and ends, but almost everything is documented and I can walk a potential buyer through it in detail.
The engine runs like a top, the brake system works flawlessly, the 4 wheel drive works great, the cooling system is top notch (i don't even run it with the fan shroud and it stays nice and cool, the fan shroud is included and I can install it prior to a sale if needed, it's just cold here in the winter so it helps keep me warm!), the winch works great, all lights and gauges function correctly (dome light needs bulb).
Having wide tires and old steering it does follow the road a bit, it's mostly on the highway, nothing major and a usual thing for these. Skinnier tires would help with that. There is an oil leak, either in the valve cover gasket or the oil pan gasket, maybe both. I don't really have to add oil but it's seeping, both easy and cheap fixes I just haven't gotten to. I haven't noticed any drips when parked. The dash is cracked and the front seats are torn. Has seat covers on now. 1 rear jump seat, perfect shape. Rust in normal areas but workable for someone looking to restore, useable as is for someone looking to wheel or just use, paint job is just a primer but worked for me, I was mainly concerned with focusing on mechanics now and bodywork later. Frame is good, nothing other than minor surface stuff. All u joints, drivetrain bearings, tre's, etc are good, no leaks other than mentioned above.
This cruiser was purchased by my father in 1999 in Fort Collins, i purchased it from him in 2011, it sat unused with a blown engine from about 2003 until i bought it in 2011 and i have since focused attention on the drivetrain and reliability aspect of it. I take care of it and don't abuse it offroad, its mildly offroaded at best but is a beast when needed. l wouldn't hesitate to drive this cruiser cross country and back again.
I also have a 1984 fj60 parts car. If a potential buyer was interested in axles, diffs, 4 speed tranny, transfercase, bellhousing, rims, seats, steering wheel, etc for a particular build that could be worked into the deal.
On to the details:
Fog lights
Center force clutch
new alternator
New spark plugs
New belts
New fuel pump
warn 9000 winch
chains
Con-ferr shackles
Fire extinguisher
Desmogged
Is there some way I could speak to you about possible purchase? I apologize I am very new to this forum and do not know protocols. Please let me know, Seth
