For Sale 1970 FJ40
Coeur d' Alene Idaho, USA
SOLD-I bought this Fj40 with the intention of learning some mechanical skills and staying with the principles of keep everything vintage Toyota and simple. The engine runs and sounds great ,transmission and clutch good, overall it drives well and stops like a drum brake cruiser. Body work and paint are not great, but it is solid and good enough for a cheap driver.
The following work has been recently completed:
Full tune up, wires and cap
stock carburetor gone through
new fuel line ,rebuilt original glass bulb filter
new hoses with inline heater installed
intake and exhaust manifold machined and new gaskets installed
adjust valves
new valve cover gasket
new full exhaust system installed
Some poor body work had been done in the past and I removed bondo covered rust in rear quarter panels, welded in new metal and replaced left rear corner. The previous owner had made and installed his own rear seal in past. I did not cover the work back up in bondo and fiberglass skimmed only seams ect... Sprayed with a close to original light blue and overall it looks good from 10 feet away.
The top and doors are rust free and all the glass is original in great shape.
Things that need to be completed or purchased:
rebuilt speedo installed
front turn signals installed
rebuild rear hatch handle with good used parts I have purchased
running boards
speedo cable
rear taillights
new tires
new rubber seals
SOLD (good running FJ40 project under 5k is hard to find)
Please call with questions #801-550-6042
located in Northern Idaho with a clear Wa. title.
Thanks, Ben
