1970 FJ40/Rockcrawler
Roseville
1970 FJ40 Landcruiser, Smog exempt, SB Chevy 350 w/quadrajet, SM420 transmission, 3 spd transfer case (with t-case saver), tilt wheel, saginaw power steering conversion, spring over axle conversion, 4 wheel disc brakes, Dana 44 front end (built by Dynatrack - cut and turned w/new front driveline), hi-steer kit w/heavy duty tie rod and drag link, ARB air lockers front and rear, York onboard air compressor w/holding tank and two extra fittings for compressor hose attachments(will run pnuematic air tools), aluminum oversized radiator w/custom shroud and fan, Brand new 35" Goodyear MTR's (less than 1000 miles) w/matching spare (never used), custom swing out tire carrier w/ice chest rack, full family cage (w/grab bars) welded to frame, custom sunbrella bikini top (you can drop down the windshield on the trail and still have coverage from sun), 4 pt harness seat belts, rear seat w/belts, tub lined with durabak coating, 4.11 gears w/fine spline pinion rear, Rancho RS9000 adjustable shocks, WARN 9000lb winch (never even spooled out or used), Optima battery, CD, CB, Grant GT steering wheel, poly fuel tank, hi-lift jack, fenders cut and trimmed for clearance, rock sliders, bucket seats, center console, new wheel bearings, brake lines (front), new master/slave cylinder (clutch), master cylinder (brakes), brake pads front and rear, motor has new edelbrock intake, water pump, electronic ignition, and quadrajet carburetor (great off-road carb), exhaust system
This is a great cruiser, fun to drive and best of all safe for you and your family to be in. The 4 wheel disc brakes work fantastic and will stop this rig very quickly. The high-steer and tight front end, keep it true on the road and eliminate bump steer on the freeway. I have reciepts from suspension and axle work done by Extreme Gear in Orangevale, CA. This cruiser is 99% rust free and has been in California since its build.
Contact Travis (916)847-1546 or t.pointer@comcast.net
Located in Roseville, California
ASKING PRICE: $15,500
I'll Take it!
It's free right???
Could you post a price per the rules? Very nice truck and depending on what you're asking, I could be very interested.
Oh yea, the price...
Sorry about the price, thought it was listed... I am asking $15,500. I do currently as of yesterday have a $500 cash deposit to hold it. The buyer is supposed to have the money to me this Saturday. If the deal falls out I will keep everyone posted.
Thanks
