1970 fj40 for sale
Roseville
1970 FJ40 Landcruiser, Smog exempt, SB Chevy 350 w/quadrajet, SM420 transmission, 3 spd transfer case (with t-case saver), tilt wheel, saginaw power steering conversion, spring over axle conversion, 4 wheel disc brakes, Dana 44 front end (built by Dynatrack - cut and turned w/new front driveline), hi-steer kit w/heavy duty tie rod and drag link, ARB air lockers front and rear, York onboard air compressor w/holding tank and two extra fittings for compressor hose attachments(will run pnuematic air tools), aluminum oversized radiator w/custom shroud and fan, Brand new 35" Goodyear MTR's (less than 1000 miles) w/matching spare (never used), custom swing out tire carrier w/ice chest rack, full family cage (w/grab bars) welded to frame, custom sunbrella bikini top (you can drop down the windshield on the trail and still have coverage from sun), 4 pt harness seat belts, rear seat w/4 pt. belts, tub lined with durabak coating, 4.11 gears w/fine spline pinion rear, Rancho RS9000 adjustable shocks, WARN 9000lb winch (never even spooled out or used), Optima battery, CD, CB, Grant GT steering wheel, poly fuel tank, hi-lift jack, fenders cut and trimmed for clearance, rock sliders, bucket seats, center console, many new parts including: wheel bearings, brake lines (front), new master/slave cylinder (clutch), master cylinder (brakes), brake pads front and rear, motor has new edelbrock intake, water pump, electronic ignition, quadrajet carburetor (great off-road carb), exhaust system, and all new u-bolts on axles.
This cruiser is primarily set up for rock crawling, but is fun to drive around town. The motor has excellent compression and runs strong. This cruiser is extremely reliable and professionally built, drive all others then come and drive this one. I have all receipts for work that was done by Extreme Gear in Orangevale, CA. Cruiser has been in California since its conception and is 99% rust free. Completed the Rubicon last year with no problems, will climb anything. I have many pictures upon request.
If interested call (916) 847-1546, email: t.pointer@comcast.net
Asking price is $15,500
