For Sale 1969 FJ40 For Sale
Canyon Texas
1969, 1F, weber carb, headers, new clutch, brakes, cylinders, masters, slave, taillights, turn signals, emergency brake, turn switch, light switch, oil lines, hoses, fenders, hardware kit, bumberettes, bikini top, heater seals, resurfaced flywheel, drums, original hardtop, new hardtop seals and install kit, new exhaust, muffler, 1 inch aluminum body spacers, polyurethane body mounts, new tie rods, drag link kit, windshield seals, used 2 1/2 inch lift springs and rancho shocks, new receiver hitch, some sheet metal sand blasted and primered, original heaters primered and painted, por15, body filler, direct to metal primer, sanding blocks, sandpaper, painters paper, sanding pads, plastic, motivation, elbow grease and money to finish not included, Clear Texas Title in my name, body is off the frame and vehicle is a project that needs to be put back together, was running before I took body off, all the drivetrain is installed in the frame I have all the original parts for it well over $5000.00 invested make me a reasonable offer call or text if interested 806-418-3065
Negative, I have painted part of the frame, sprayed the uderside with undercoat, installed the 2.5 lift springs, installed the 1"body spacers and poly body mounts and installed the tub, also applied truck bed coating in part of the tub
Rust Issues?
From the pics it looks like the tub and frame are in pretty good shape. Does it need any sheet metal repaired or replaced? Also, I am way out in NC, would you be able to get it put together enough (body and top on the frame) for it to be shipped? Thanks!
I installed the tub and will most likely have all the interior, doors and windshield installed in a week and other odds and ends installed and done, rust on the rear channel of the bed where they always rust, dented along the drivers side by the door rocker, few other rust spots but overall solid metal for 42 year old metal.
