For Sale 1969 FJ-40 Loaded Rockcrawler in TX.
Custom front and rear bumpers with recessed rear lights with cages and D-rings and Receiver tube.
Frame attached gusseted DOM roll cage, tested twice and still holds true.
WARN 8274 Winch on custom mount.
Dual batteries and Isolator.
Rewired most things to operate from the top of the roll cage on fused switches.
Dual KC 150 Watt Highlights
40 Watt Drivers Running rock lights
Custom Headlights, Autoroche or something like that.
Real 16 bolt 15x10 Bead locks
37x13 x15 Swamper Boggers with excellent tread Spare is a 37” TSL Radial. On a custom swing out tire carrier.
ARB Air compressor,
ARB Air Lockers front and rear.
Square tubing Driveshaft’s.
Newfield replacement axles
4-wheel disc brake conversion.
Leather High back seats from a Toyota Celica Supra.
Rear mounted Air tank
Rear mounted 60” Highlift
Rear mounted ABS Toolbox
Custom Rear Diff guard, Very unique and protective.
Traction bar. To prevent axle wrap.
Original F engine with a Holly 2 bbl carb.
Header with Flowmaster muffler
Saginaw manual steering conversion
Interior Dura-back coating treated.
Under bed Aux Fuel tank. Under pass seat tank will be included, Soon to be ex-wife did not like sitting on it.
It has 2½” Rancho springs on top of the axle
Flipped and reinforced steering linkage.
In case you want, I have a 350 V-8 that had a fresh rebuild on it 2 years ago, and has been stored, I also have a SM465 Transfercase. If you don't give me any grief and offer cash I will toss in those items and a Engine mounted welder and regulator, not a homebuilt unit, a professional one.
Many more pictures on my Flickr Account: FJ-40 for sale - a set on Flickr
