1968 Side Marker Reflector
Lopez Island Washington
I've been searching all over for the side markers, cannot find any. Purchased the red lens rear reflector and it actually fits the holes for the side reflectors.
Anyone have a suggestion?
Those are marker lights. 68 and 69 models used a amber reflector. For some reason the amber lenses faded much worse than the red ones. Finding a good used paired not fade isn't that easy. Because of the angle of the apron there is a wedged shaped rubber spacer that went between the apron and reflector.
SOR currently doesn't have any.
http://www.sor.com/catproducts.sor?from=160&part.number=160-02&tabpage=TAB1
Gotcha, sorry. I didn't realize those (68-69) had reflectors only.
http://cruiseroutfitters.com/exterior.html
40 Series Rear Reflectors
Fits Passenger or Drivers Side (Right and Left)
OEM Toyota Part, 2 required per vehicle
Part# LENS69015 - $39.50 each
(Fits 1958 - 9/1973 40 Series Only)
Never used cruiseroutfitters, but I'm sure someone here has.
I remember the thread about replacing the reflector would just want to be sure it was a Koito lens. As for Cruiser Outfitters those are red. SOR has them also. They work for rear side reflectors but need amber for the front. I'm not 100% sure the studs would be long enough. The rear reflector studs are long then the red ones used on the side which is no big deal. Because of the angle of apron the rubber spacer is pretty thick requiring long studs.
Both SOR and Cruiser Outfitter claim 58-73 for rear reflectors but really only used 68 and 69.58-63? used American made lenses installed here. 64?-67 used Koito lenses but had a flange in the ring that had two hole to use screws. 68-73 had studs out the back.
Damn, you'd think with the interwebs all synced up to everything, the stuff you needed wouldn't be so difficult to find.
:hhmm:
That's my life story in a nut shell.
Wow, you guys have answered everything, thank you. I always type the wrong stuff in for a search and never produces anything, thanks for sharing that reflector thread.
Living in the Past.. Have you seen where to get the spacer? SOR doesn't show it and if I could see one I might be able to make one myself. And you're right about the studs on the red reflector, from the pictures of the side reflector on the other thread they are much longer than the rear one that I bought last week.
Thanks again for all the help.
Supply and demand. Only two years production doesn't help that. The side red reflectors are NLA. The rear reflectors are still available but those were used 68-73 and because they work on the side for 68/69 models it increases the market. Plus they market them as working back thru 58 either which also doesn't hurt. Besides only two years on the front reflector you should have the rubber pad which is NLA.
What I do find funny the amber lights in the bib were only amber 68/69 but are still available new OEM. Every cruiser imported from 58-67model had clear lenses but those are NLA. Seen many high dollar restoration that should have clears lenses with amber lenses. Which is the restoring just saving a few bucks since repos were available but not as cheap as the new OEM amber lens.
didn't DOT change the requirement to use amber for the parking lights?, maybe around 1967/8, so when Toyota made more they went with amber over clear as that was the law going forward
I agree it was done for DOT requirements but early models won't have comply to the newer law and could have used the correct clear lenses. Just the way Toyota does things. The amber lens fits so buy two of those if you need one or run a clear and amber. Instead of still providing the correct clear lens. Guessing 58 to 67 sold more cruisers then 68/69. Besides 40 earlier included both pickups and wagons. The LV or US imported pickups never had amber lenses.
and this is why I have no seat belts in my LV.....;) I prefer the option to dive out of the way of the harpoon steering column...that what I tell myself anyway
years ago I almost tossed(and replaced) my red seatbelts in my LPB until I realized they were OEM.....
I have 62 production FJ40 that was set up for seat belts. My 64 production FJ45LP-B still had one of the original red seat belts. Didn't your LV have seat belts originally? Not overly concerned about being harpooned by a steering column. In all my years searching thru junk yards I have never came across a steering wheel that failed. I did come across a 79 with 30K mile by in 83. It was crashed in both the front and back. Bought a bunch of stuff off of it. Purchased the roll bar and three point seats mainly because of the head mark in the windshield from the driver's head. Used these for years and the belt locks up when I hit a bump so I know they works and 79's owner wasn't wearing it at the time of the accident. Because I bought the perfect doors off of it I also purchased the steering column so the locks would match. Don't remember the steering wheel being bend. Steering shaft was find but tub around it was bent. It's crap shoot what is really best but I take three point seat belt over lap or none.:cheers:
no the LV never had belts in it(no eye bolts or anything), "supposedly"(story I was told but someone) it was going to(ordered for) the Mexican police but they never took delivery of it. No heater either(but I have the ND optional one in the shed)
I kid about the harpoon steering.....
Rick D. told me the story of the LVs headed to Mexico and the deal fell thru s0 they ended up in the US. Curious like the reflector added here why DOT make them install seat belts to sell them here.
To keep this on the subject of reflectors 68 was the first model that had them install at the factory. Everything else I've seen was aftermarket with nothing matching vehicle to vehicle like the Stratolite that were on most early cruisers.
I know it wouldn't be stock but then again I found out the the top was originally green and the body was that plum color and it's been converted to a 4 speed, so... I'm thinking maybe install the later years side marker lights? Or getting another rear reflector and finding some amber reflector that fits in the housing.
I can probably get you the length of the studs on the amber reflectors so you will know if the studs on the rear will be long enough with the rubber spacer. This spacer is thicker than the metal on the rear frame member. I do know the marker light was in front of the apron emblem while reflector was behind the emblem.
I'd probably have to make the rubber spacer, can't find that anywhere either. I have 1/8, 3/16, 1/4, 1/2 and 3/4 rubber so I can cut it out of any thickness. Unless you have a line on where to get the spacer.
I want to keep it stock as much as possible. When I do the frame off (way down the road at this point) I have to replace the dash, the PO cut it to pieces then installed an over patch. But in the mean time I'm looking for as much of the stuff that I can revert back to stock as possible.
I'm on the home stretch of a 7yr frame off resto on a 69 fj40 and went a slightly different route. I wound up buying two of the rear red reflectors from SOR Land Cruiser Reflectors - https://www.sor.com/cat160.sor and then found some 3" DOT stick-on amber reflectors from Stick-On Round Reflectors - 3", Red or Amber - https://www.delcity.net/store/Stick!on-Round-Reflectors/p_57452.h_57544. I had to take a die grinder and shave off about 1 mm of plastic from the outer rim of the reflector, but they then popped into the recess of the red reflectors with a nice snug fit. Between the tight fit and the self stick-on backing of the amber reflector, I don't think they are going anywhere. They sit completely flush with the red reflector rim.
