1968 fj40.
1968 Toyota FJ 40 Land Cruiser. Newly rebuilt Chevy 350. Holley Pro Jection system. Edelbrock intake. Custom 2.5 inch exhaust with Flowmaster muffler. Premier performance 700r transmission. Stock early model Transfer case with twin stick shifters. Arb’s front and rear with Arb air compressor. 4 wheel disk brakes, front off a 79-85 Toyota mini truck, rear is the Downey kit. All steel braided lines. New 4 core radiator with two electric powered fans. Spring over axle done by Tri County Off Road. Front axle has knuckles cut and turned. High steer kit with 1 ton rod ends. Spring reversal. Power steering. Sway bar with disconnects. 35” inch tires with Mickey Thompson 15 – 10 Alcoa’s. Rancho 9000 shocks on all 4 corners. Warn 8724 Winch with fresh seals. Tuffy center console. Two rear lockable boxes in rear above fenders, I don’t remember what brand. New used fuel tank. Con Ferr rear seat. Will included a set of Metal Tech Tube fender kit, Not Installed. The truck has been sitting for a while. Front Knuckle seals are leaking. Transfer case rear seal is leaking. Rear ARB leaks air but still works. The compressor just cycles a little more. Body is in good condition. ¼ panels have the usual rock rash. Hard doors have a little rust. Rear under doors is also starting to rust. None of the rust spots are major. A little body work and paint and it would look great. Delivery MAY be possible depending on location for the price of fuel and hotel. Check with me first! Overall the truck is in good condition. Could use a little tlc. Holley projection system could use new injectors, or be replaced with a carb. I don’t have time for it, and have too many other projects to finish. Truck is located in Riverside if you want to check it out. Currently non-operational thru DMV. Ebay item number is 180329848781.
