For Sale 1966 FJ40 alum. tub v8 daily driver.
This truck has been daily driven since restoration and has proven to be very reliable.I have daily driven this truck for almost 14000 miles with the only problem being that I had to replace the starter. The frame is in excellent shape. I have all parts for the hard top except the fiberglass cap. I have a new headliner for the cap but no cap. This truck is available in Tampa Fl. I have nearing 20k invested. Will let it go for $10k. Please call me for more info and questions. Ryan 813-957-7112, rfrisco90@aol.com
The best of everything - no expense spared - almost all new parts
Aqualu Aluminum tub and firewall
Man a fre front winch bumper (new)
ARB Safari snorkle (new buts needs connection to carb)
Painless wiring waterproof harness (new)
IPF backup light (new)
Man a fre Shackles (new)
starter (NEW)
Confer lockbox
Crate 350 (new at build 13k miles)
Edelbrock Intake
Holley truck avenger 650cfm carb (new)
Accel HEI distributor (new)
Turbo 350 Auto
Orion T-Case 4:1
Custom driveshafts
Fine spline cruiser axles, rebuilt diffs (rear - all new components assembled by Randy's ring and pinion)
ARB Front and rear Air Lockers / High output Air Compressor (new)
Saginaw Steering with Borgesen shaft
Optima Battery
100 Amp 1 wire alternator
High flow steering pump
Auto Meter Gauges
Mojave heater
Art Carr shifter
Custom .120 DOM full rollcage
Fiberglass rear half doors
Procar Elite seats / mounts
Cool Cruisers seatbelts
35" BFG muds
Rancho RS 9000xl shocks
Old man emu springs (fronts are new)
All parts for hard top (except fiberglass cap) - just needs assembly
Steel full doors
Griffin Aluminum radiator
Flex -a- lite Black Magic fan
Painless wiring waterproof wiring harness (new) all connections are dielectric greased
Fuel/water separator
Hilift jack
full length bikini top
Here are the things that need to be finished:
Turn signals are wired but turn signal stalk is not (new oem turn signal stalk)
trans pan gasket is leaking
heater needs wiring completed
front fenders are steel and have some rust spot showing
NICE RIDE WISH I HAD THE CASH
Ill trade ya for my orange FJ60truggy loaded on the trailer with the propane installed... just s idea :grinpimp:
