1966 Fj-40 Has to go
Lost Coast of California
Hey all,
My 1966 Fj-40 Has to go. $1000.00 for the complete package. Or I will sell it piece by piece. The entire fj-40 is in pieces and is not cataloged (photographic memory).
I have authentically repaired the Driver side rocker sill & front bib rust. The drivers side floor pan is rotted, Passenger side Rocker and of course the rear sill area. The front clip bolts have been drilled & tapped where broken off. The 6mm bolts holding the hard top to the tub are broken and still need to be drilled & tapped.
I have stripped off 80% of the frame's rust & layers of undercoating. The front clip is off the car (I can install it to make it a roller) Have new 3" longer shakles, Bushings and greasable shackle pins for the front springs. Drilled & tappes all threads from the center skid plate forward.
Have a 1975 F engine (Domed pistions). The bottom end has been cleaned up, Re ringed, New bearings, Head still not done. Block on stand & u get that too if you want it.
I am in Eureka, Ca and travel through the north end of the state twice monthly. I can deliver the vehicle or parts through the following areas.
Redding through Sacramento, Eureka through Ukiah, Sacramento West through Folsom south to Angles Camp.
I have pictures so feel free to email me and please tell me if you have Dial up so I can reduce the quality of the pictures for you.
I also am selling my 83 Fj-60 in that forum.
Thanks,
Dave.
