Build 1965 FJ45lv build up/resto thread
1 here, 3 more
Please refer to the above paragragh on my hinge question, need some help here please!!!
Matt, went out and looked at doors... because I received mine in parts, it was pure luck that my passenger side doors still had hinges on them.
Here is what I have.
Passenger Front seat = #2 Top - #4 Bottom
Passenger Rear seat = #6 Top - #8 Bottom
Thats all I can contribute as the others have been taken off already.
Hope this helps!
looking good..
Mikesta
Hope this helps!
looking good..
Mikesta
YES!!!, that does help, but we need to get a little more info now. I am going to assume at this point (Ass-u (and) -me) :) that the driver side is the same. If your hinges are still attached to the DOOR, you are looking at the portion of the hinge and # that attaches to the vehicle, CORRECT???
If you could do me a huge favor, 1 by 1, remove the 4 bolts that hold each hinge in the door, slide that hinge out and tell me what # hinge is attached to it. i.e.: #2 hinge is attached to......#1 ??? Hinge?? This is just a guess on my part, but it soulds like you have the answer(s) I need. Whatever #'s and sets of hinges you come up with, I bet it's the same on the other side, since there are 2 of each, 8 #'s total.
I would make sure you take each hinge out 1 by 1 and put it back, or label them correctly. At the very least we and all others will have this info on this thread now if anyone else needs it. I am almost 100% positive that your #2,4,6,8 hinge will be attached to #1,3,5,7 - now, we/I just need to know the correct match for each set. With the info you have with your hinges still attached to the doors, should be good to go!!
If you could do that, sure appreciate it, I would like to get these hinges back together ASAP. If anyone else has there doors off, or hinges labeled, please post to confirm................
Thanks, Matt
Mike, one other thing.
If your other set of hinges are off the other door and vehicle, but are still pinned together???
If yes, you might be able to tell me the answer without removing them from the other door. Although you might want to do that anyway just to make sure there the same.
If your other hinges are still pinned and out, take a look, should be the same?
Thanks again, Matt
It is 1:00 in the morning but I was waiting for a load of laundry anyway :D
I can pull the other doors tomorrow when the sun is up if you want.
Once I wiped all the blood off the hinge and myself ;) it looks like the passenger rear door top is 5 & 6. The passenger rear bottom hinge is 7 & 8. The short side looks to be the odd numbers and is also the side that goes into the door.
I taught that bolt a lesson, only broke the head off one and it happened to be the one right next to all the lovely, and shap, rusty metal :doh:
Dude......I need info, but I don't want anyone taking a bullet for door hinges :)
Your hardcore man, I like it :D Exactly what I probably would do at 1:00 a.m. if someone asked and I was awake.
Your #'s are confirming what Mikesta has got also, at least in terms of hinge location. I guess if it's not to big of deal I would like to make sure that 1 & 2 are a pair and 3 & 4 are, as long as you don't clean off another finger in the process. ;) Just want to make damm sure the pairs are right before I pound those pins back in, I don't want to take them apart again.
Thanks, Matt
Matt, I will take a look tonight... and confirm what Mike wrote. Mike, way to go... taking a bullet for the team! GO TEAM!
well....blew that theory all to :censor: :D
  • Passenger rear top........................5 & 6
  • Passenger rear bottom..................7 & 8
  • Passenger front top.......................1 & 2
  • Passenger front bottom.................7 & 8
  • Driver rear top..............................rusted in the truck
  • Driver rear bottom........................rusted in the truck
  • Driver front top.............................1 & 2
  • Driver front bottom.......................7 & 8
The driver's side (LV) rear door is rusted solid to the body for now.
UGLY... or perhaps the installer didnt know how to read?
I am really confused now :confused: Why you would have 3 sets of 7 & 8 ??
Mikesta, I need you to look at all of yours now. I guess I'm figuring that my 2 sets of 3 & 4 are a matched set. I'm kinda thinking my 3 & 4 hinges are the front bottom hinges on passenger and driver side because Mikesta is showing # 4 sticking out of the door he is lookin at. That is also assuming that the PO of Mikesta's lv didn't pull the hinges out of the doors and then re-install them in the incorrect postions?
Treeroot, did your doors front doors close ok? As I said in my earlier post about hinges, it looks as though there are only 2 different sets of hinges although they are #'d 1 to 8. If you lay your hinge sets flat, I think you'll see that some of the pin holes are obviously further away from the hinge than others. I guess see what you think??
Matt
I will uninstall the 2 sets I have and post a pic for you tonight... I will look a little harder through the "basket case" of parts and see if I can locate all the hinges, clean them up a bit and post a pic of those as well.
Cheers
Cheers
Mike, were those 2 doors on the wagon when you first got it? If yes, did the doors close ok?
Matt
The first photo is the passenger front hinge set. The short sides of all the hinges go into the doors. If you tried to put the long side into the door it would bottom out. The location of the tapped holes are in different locations on some of the hinges.
If there are 8 sets of hinges and 4 are different from the other 4...... That might explain why you have a 7 & 8 set of hinges on your front lower doors and Mikesta has a 3 & 4 set, the offset on the hinge could be the same between those 2 if I am right about 2 equal sets of different hinges out of the 8?
Just a thought?
More confusing than ever :D
The top two fronts are longer where the pin is set. Both of my front upper hinges are longer and are both 1&2 sets.
The rear uppers appear to be the same offset as the other hinges.
I'm really going to have to give my hinges a good look over tonight?? Your right I am totally confused.
I am 99% sure I'm safe pounding the pins back in them in the #'d sequence now, 1&2 / 3&4/ 5&6 / 7&8. Just have to make sure I have a left and a right so the pins are pointing down.
As far as location.......leaning towards -
1 & 2 front upper
3 & 4 front lower
5 & 6 rear upper
7 & 8 rear lower
I bet this is what Mikesta's going to have when he gets home tonight.
I guess if I get the sets in the wrong spot, not so big of deal as pinning them together incorrectly.
One thing I was thinking of as why they maybe had different offsets is to adjust the doors in the jams. You have the bolt adjustment inward and outward on the pillar and door itself. Although if your door let say had a larger gap on an upper corner vs a lower corner if you were looking at the door from the side. They (Toyota at the factory) could change the offset of the pin/hinge and that would change the positioning of the door in the jam?? Just a thought since there is not a mechanical bolt for that adjustment in the door. That would mean though that all of the hinges should be different, maybe subtle for minor adjustments. Maybe would explain why Treeroot has a 7 & 8 where Mikesta has a 3 & 4, difference's coming down the line at the factory???
Again just a thought??
Going to be leaving shortly, about a half an hour, heading up to body man buddies to shop to pound some metal.
God I want to get this hinge thing figured out???
Matt
This my friends is why they no longer allow drinking on the job!
