1964 FJ40 project
I have a 1964 fj40 and a 1972 fj40 for parts. This is going to be a frame off project. Is it worth changing out the running gear from the 72 to the 64? I plan to run a gm 350 and if I can a 6 speed manual transmission.
Thanks for the input. So what year do I have to go up to to get the fine splines? Or am I better off with something different?
go at least 1976 to get fine spline axles and disc brakes. better still 79 and up to get fine spline pinion, larger bell on birfield and wide knuckle pattern
Are there any newer axles with disc brakes that fit under my fj40? I am in no hurry to finish this, but I want it done right.
any fj40 axle fits, you may have to change the pinion flange.
68 -75 gets you course spline birfield instead of ball and claw, but still drum and course spline pinion, small kncukle pattern, small bell birfield
76 -78 is small knuckle small diameter longer length birf, but fine spline, disc brakes, course pinion
79 and newer gets you the bigger bell birf, shorter stub and bigger knuckle pattern, fine spline pinion.
once you have an axle, determine if you have course or fine pinion and buy the round pinion flange from cruiser outfitters.
if staying drum, you will need to put 10mm line nuts on the line to the axle and reflare the line.
disc brakes will require a bit more. on late 60s/early 70s, you would remove risidual valve in the front circuit on the master, but the early master is single circuit. may need to change to a dual circuit setup, that will take some replumbing of the rear circuit and putting a 10mm line nut on the line at the newer master
what's your location:? maybe someone close by can help you figure out exactly what you need to do
