1963 swb fj45 restoration
2f
4spd
all parts sand blasted
new clutch
new carb
new manilfold
rebuilt transfer case
front disc brakes
new 33 inch pro comp
4 original landcruiser rims, with hubcap clips
powder coated frame
re arched springs
greasable shackles
will continue to post pics of build,
Whislter BC
swb 63 updated pics
floor is lined,
back cab wall lined,
fire wall painted Poly urth black,
rims sand blasted, primed/painted
new hubcaps are ready for install once paint dries
swb 1963 updated pics
original 63 fj45 hood, sand blasted came out 100% perfect
new OEM manifold/exhaust bolts,
original side steps, sand blasted the grind to clean up
those running boards had a tread type rubber on the top.. Just fyi.. looking awesome. Wish I was heading that direction.
When I sand blasted the 63 side steps it erased that textured rubber that Toyota installed from factory. I will be painting the side steps dune beige code 416 with a textured beige on the top of running board. Hope it comes out nice
will post pics soon,
ordered my brake booster adaptor as I have installed front disc brakes, 1 week till till it arrives
hopefully going to place the 63 fj45 cab on the frame THATS if I get another set of hands this weekend.
Rad is now installed, new hoses, brake lines x 4 ordered,
once the cab is placed on frame I will re install my 77 electrical harness.
maybe just maybe I will get to start it this weekend. Owned it for almost a yr now and still havnt turned it over. Anticipation is killing me.
1963 swb fj45 added pics of build
additional pics
mounted the cab, still sanding n priming
mounted the fuel tank
swb fj45 box patched all large holes
1963 fj45 swb additional pics of build
patched some weird antenta holes in cab
replaced 1 cross member on bottom of swb box
patched all rot in floor of box
jt outfitters has the booster adaptor, it was around 60 $ + shipping to Canada. so like 100 with brokerage. Kinda a waste of $$$$$$$$$$$$$$ big time, but will save me time in the end, I should have made something instead. just my advice
my advice is to read up on JT outfitters before buying anything from them.
1963 fj45 resto, added pics
additional pics
spent numerous hrs on the 63 roof, wanted it straight n perfect, lots of little dings and minor rust that needed patching
