I have looked at all the posts I could find. I believe the front axle is 1962, but definitely pre 1969 since they have 8mm flange holes.
Pulled the front passenger brake drum off and it is coated in very thick heavy grease. When I bought this there was no signs of anything leaking on the tires, rims or outside the drum. I can see it leaked at the back of the hub but in front of the brake pads where the front hub would spin.
From reading I think I need to replace the inner and outer seal. Are they the same seal or are they different. I do not need to rebuild anything. Jacked up the wheel spins freely smoothly and has 0 play at all. So it all seams real tight.
Do I just need to buy the inner and outer seals. How hard is to to replace them, is it the same for other years. Are the seals the same from 58 to 75 like SOR says. I read marlin has good seals but they show the inner seal but did not find an outer seal and it lists the inner for 1969 to 1980 and I know these are pre 69.
Need some clarification on what I need to buy where to buy and how hard is it. I want to do the least amount possible both in effort and $$$$. This is not nearly road ready so if I pull it and see the bearings are bad I will deal with that, but I think they all good.
PS If anyone wants to send me the money to upgrade the axles to disc brakes I will entertain the idea, other wise please do not recommend it. Our dog is going through chemo and all my budget I had for the rebuild is drying up fast, but seals look like they will be under $30 total, and I can clean the brake shoes and replace them before I actually put it on the road.
