Wanted 1962 FJ45 Last few parts to finish the build
Montana
  1. 45 Series
I am in need of a few last items to wrap up my 1962 FJ45. Any help would be greatly appreciated!!!
•TNK wiper motor and arms
•choke cable assembly
•throttle cable assembly
•rear license plate frame
(I use to have but unfortunately it never got returned from body shop and have not been getting a response about it.)
Below are photos of the license plate frame
And the choke and throttle cable I need.
Here is the build thread if your interested.
View attachment 3643788View attachment 3643787View attachment 3643786
Reach out to
thundermcawesum​
he should have whatever wiper parts you need beside the motor mentioned on this post.
Karma in full effect.
T
what exact particular License Plate Frame Lamp Assy. applies to this super early 1962 FJ45 rear frame ?
do you have a
FJ45LV ?
or
a SWB / LWB
P/U ?
Short wheel base. There is a photo of the license plate frame at the beginning of this thread. It’s the backside of it and it was painted green at the time.
Thanks for reaching out!!
I had reached out to you a few times and was hoping you would have the choke and throttle cable I need??
do you have a
FJ45LV ?
or
a SWB / LWB
P/U ?
Bump.
Last thing I need is a license plate frame for like seen in my photos. Have searched and searched but have not seen one.
I will make it worth your while if someone comes out with one.
Thanks!!
That looks like a fj25 license plate frame
Except it's upside down. Light was on the bottom and much smaller housing.
If you are after a license bracket for US market it was there same from 61 to early in the 74 model.
61 FJ40 I sold.
62 FST tub I still have.
Tailgate on the left was off a 62 FST I pickup up years ago. Upper bracket was obviously removed but it has the two fixed nuts along the bottom.
The last image doesn't see to be there. My down load clearly shows the two nuts with bolts broken off.
If you look closely you see the upper bracket is screwed on versus being spot welded. FJ25 license plate bracket was held on with screws as well.
I have the fj25 bracket for my 1958. I could assist you measurements and or template.
That would be awesome. Any photos of measurements or even a template I would love. I just bought some material and will look to try my hand at making one soon.
Thank you for your help!!
I need a blue sd-40 sight window plate.
And tailgate chains and this thing is done.
Anyone come across some or know who I should reach out to? That would be awesome.
I know this is a long shot.
