17" wheels
Boulder, CO
Anyone got pics of 17" wheels with 35" tires on a 80 series, I'm thinking about getting some and just want to know what the setup looks like.
You probobly won't be able to tell the difference (visually) between a 16" and 17" wheel'd rig, until you get up close.
17's, but with 37"s.:o
17''s w/ 315's (about 34.6'') bfg at's.
16''s w/ 35 trxxs MT
Heres mine with 17" fj wheel love them...
Sorry no 35's yet but heres some 295's
If I go 17 it is to have more options in a 37 inch size. More options in 37x12.50r17 than in r16 even counting metric sizes. With a 315 (~35) I can't think of any huge gains since there are more choices and lower prices on a 16 wheel.
From what I have read, here and other places is that you should try for at least 10 inches of sidewall from the rim to the tread, for airing down purposes. I have 17s with 37 inch Toyo's here is a poser pic:
any level ground shots so I cAn see how it looks. Also how much lift with those 37s. FOR lift, 4x4 labs rear bumper and 5 tires are my pressing issues.
Can any of you, who have the Tundra 17" wheels on, tell me what the wheel's offset is?
I have a set of 17" JDM wheels but they have +3 offset. Just making sure that they will fit properly and won't rub anything before I have them mounted. I'm planing one pairing them with 285/70 R17 BFG KM2, if that's matter.
Hate to say it but use search the topic of wheels from other toyotas with different offsets has been discussed before.
Who were you referencing? they are all level ground shots except armyfj's, unless your looking for super level concrete shots. edit: reread; i think tools has j's and a spacer up front, plus his arms. dunno bout army's.
the backspacing is 5.5'' or one inch greater than stock. the tires will rub the rear wheel well a bit sooner upon compression than the stock 16's but i do not rub the frame anywhere even at full lock w/ the 315's and j lift.
... Also how much lift with those 37s. FOR lift, 4x4 labs rear bumper and 5 tires are my pressing issues.
Mine is OME J's with 1.5" spacer, the rig is relatively light, ARB front, 4X4Labs rear bumpers, it sits ~5" over stock. At my weight and the type of wheeling that I go (lots of flexing) I'm very happy with them, they ride and flex great! I wouldn't want it any higher. If your planing a heavier rig you may prefer one of the stiffer springs, OME comps or Slees are available in that size of lift.
The 37's aren't a "bolt on" deal, some mods, tuning will be required to run them. I found that narrower tires fit much easier. That's why I wound up with the Cooper STT's on 7.5" wheels. They are a relatively narrow combo allowing them to stuff into the wheel wells for good travel/flex.
looking at hankook MT in 37x12.5r17. Pretty narrow especially compared to say toyos wider when same size tire plus only have a 13.50 in a 37.
I haven't seen the Hankooks. But wanted the Toyos, due to my great experance with the Nittos (same Co). The Toyos measure over 14" section width, side by side much wider than the Coopers (12.5"), so went with the Coopers. My goal was to get as much flex as possible and keep the flares, they have worked well.
That's +32 offset, assuming the wheel width is 7.5". No doubt why the tires rub. Mine should be fine then.
I have Slee 6 inch lift, I rub my tire on the exhaust little and a little on the inside well. I Am getting ready to throw some spacers on to see how that helps the problem.
What kind of wheels do you run? I couldn't see them clearly on your avatar.
