16x7 or 16x8 steel Toyota wheel?
On the farm
Does Toyota make any 16x7 to 16x8 steel wheels that would fit a stock '94 4x4 pickup and if so what is the back spacing and Toyota part number?
I found numbers for a 16x6 and info that the only 16x7 they made is hub centric rather than bolt centric like the mini truck is. I'm not positive on the 16x7 info. I'm looking for a wheel that I can put a 245x75r16 tire on. The tires want 6.5" to 8" wide wheel. I'd like to go with 16x7 if possible and if I go after market that is what I'll get. The hub has 6 Bolts on a 5.5" circle. The hub hole diameter needs to be at least 4.125". Backspacing on my stock 15x6 rims is 4.75" measured from lip to mounting face.
Looks like I just needed differnt search criteria. 16x8 heavy duty 80 series stock wheels.
The OEM steel wheel, 42601-60361, is 16x8 with 4.5 inches of backspace and zero offset(exacly the same as the alloy wheel). They weigh ~43 lbs a copy(over twice what the alloy weighs) and are easy to balance and difficult to damage.
Still looking for a 16x7 part number. I now see that Tundras have one that may work but the hub hole might need enlarging.
