12ht weight
toyota technical specifications say,
2H engine service weight (5m/t) 330 KG
2H engine service weight (4(a/t) 318 KG
transmission weight (5m/t) 65.1 KG
auto box weight (4a/t) 138.8 KG
transfer box weight (5m/t) 36.2 KG
transfer box weight (4a/t) 37.3 KG
Can't be that much difference between a 2-H and a 12-HT
Hope you are sattisfied with this info,
Some people told me that the engine has between 300-326-350kgs, I've needed exactly the weight, did you check any web site for that ? if is ok can you send me the link, please?
Thank
How much does a 12ht weigh with no bell housing, no starter motor, no alternator , no fan, no fluids for shipping please
regards pood
The 12Ht is a heavy engine, the IP is a 1/3 larger than a 2H's, the exhaust manifold is heavier, you have the turbo, shields & fittings, (2) air intake & outlet manifolds, extra assorted piping, oil squirting fittings and a heavy flywheel.
Remove the items as mentioned in the above thread #9 it still would come in at around 300kg.
