Toyota 12ht engine ..can anyone tell me what the numbers mean ?
hey thanxs for that info ...i googled the numbers ..and coudnt find ...so it looks like there rigidij originals ...i can see crosshatch in the bores ..so i mite get a few more cliks out of her ..i am pretty excited about a 30 year old engine lolD8L D + manufacturing date and plate code. I assume this is from an engine manufactured in 1988?
1 = bearing size, AKA: MARK 1
For the BEB's on a 12H-T, you only have two possible bearing size options: Mark 1 or Mark 2. The bearings will indicate what size replacement as long as you are not machining the crank, then you would go with a bearing sized kit (.25/.50/.75/1.0mm under). At least from Toyota.
Reviving an old thread here because I am curious.D8L D + manufacturing date and plate code. I assume this is from an engine manufactured in 1988?
| 11071-68020-01 | 12HT,2H..HJ6# NO.2,MARK 1 |
| 11071-68020-02 | 12HT,2H..HJ6# NO.2,MARK 2,MARK 2 |
| 11071-68020-03 | 12HT,2H..HJ6# NO.2,MARK 3,MARK 3 |
| 11701-68020-01 | 12HT,2H..HJ6# NO.1,MARK 1,MARK 1 |
| 11701-68020-02 | 12HT,2H..HJ6# NO.1,MARK 2,MARK 2 |
| 11701-68020-03 | 12HT,2H..HJ6# NO.1,MARK 3,MARK 3 |
