I cannot read the part # on Mine - 1981 BJ42 RHD from NZ 12volt with 6wire square plug. no extra ground wireWhere might I get a new Regulator
27700-15011 is the part number for an ARL spec vehicle , so it should be ok for NZ. Put the number into google and see what you get.
Great resource. I'm working through converting my 1980 BJ41 from a 24V to 12V, so I was looking for a 12V voltage regulator. Mine currently has a 6 wire square plug.
I’ve truly thought about that. Just can’t nail down the correct part number for an internally regulated alternator with a vacuum pump that will fit my mounts. Please share if anyone has that info. Thanks.Given the scope of your change, why not convert to a readily available 12V internally regulated alternator as well?
