10m Ham Radio F/S
Status
Not open for further replies.
bkfj40
Wishin i was in Wydaho
new erection, va
htx-10 Radio Shack 10 Meter Mobile Transceiver - Brand New in Box - I opened it only to make sure it powered on.
Willing to trade for either a 2m ham radio or a 75WXST CB radio (all-in-one)
or $90 (includes shipping in the cont. US)
Brian
bk@engsoln.com
from the radioshack.com site (search for htx-10) - fyi - I'm dumb about this stuff....I'm a structural engineer, not an electrical engineer :)
HTX-10 10-Meter Transceiver
(190-1110) Features Faxback Doc. # 56896
Your RadioShack HTX-10 Meter Transceiver is ideal for use in your vehicle.
Its 25-Watt SSB/FM and 7-Watt AM output provides the power you need to
communicate, and its tuner covers the entire 10 meter Amateur Radio band
(including the 28.3 to 28.5 MHz Novice band). You can connect a DC power
supply and base station antenna to your transceiver to set up a base
station in your home. The transceiver's crystal-controlled circuitry
provides accurate and stable channel selection, making it an ideal choice
for your amateur communications needs.
Your transceiver has these advanced features:
Large, Illuminated, digital - clearly shows the frequency, functions,
Display and incoming signal strength.
1 kHz Frequency Resolution - lets you fine tune frequencies for optimum
transmission and reception.
Scan - the transceiver scans its frequency range
for transmissions.
MIC and RF Gain Control - lets you adjust the microphone and
receiver gain to match the strength of
the received signal.
Switchable Noise Blanker - reduces interference from ignition
systems, motors, and other electrical
equipment.
Squelch Circuit - compensates for signal fading and
eliminates signal chopping.
Automatic Gain Control - maintains a constant volume level,
regardless of the signal strength.
Built-in Automatic Modulation - ensures a constant RF modulation level.
Control
additional info can be found here:
http://support.radioshack.com/produ...id=19-1110&Name=Ham and Marine Radios&Reuse=N
I'm located in Harrisonburg, VA - a 75wxst cb is an all in one cb with a remote mounted base, it is has all you need right on the mic...
bk
Status
