100 vs 200 Wheel Bolt Pattern
Contemplating the new LC and have a set of spare wheels from the 100 series. Both are 5 bolt pattern but Im not sure about the mm. Does anyone know if the 2007 LC wheels will fit the 2008 LC ?
Thanks
As the great american said, Same sh!t different day.
I almost thought this was gonna be the first 100 vs 200 thread! :lol:
If they are 5x150 they'll fit. Not much help, i know.
Oh God, please no!
Anyone know about the offset?
First thing to check would be the diameter: 16" definitely won't fit because of the larger rotors. I know it comes with 18" but I wonder if they have clearanced the 18" wheels for the larger rotors or if the 18" hundy wheels will fit?
To clarify, I have the 18" LX470 wheels (model year 2006 style).
Here in the middle east, the new LC is only being offered with 17" wheels from the factory so I would imagine that the brakes wouldnt be that big or that big of an issue.
The wheels I have are 5x150.
Just wanted to know if the new LX is same bolt pattern?
hello to all! I just fitted the 18" of the 100 to the 200 and needed a 5mm spacer. the caliper hit the inside spoke of the wheel. everything was fine after the spacer were installed. although the offset was the same i think it was the design of the wheel that caused.;)
I was just thinking of the opposite thing. Wanted to put wheels from 200 to my 100. Presumably they have less backspacing...
I can post the picture her too, of the 2001 100 series with 20" 200 series wheels!
The 200 series have 60 mm offset, the same as the 100 series. The 20" wheels are 8,5" wide, the 18" wheels 8" wide. Backspacing of the 18" 200 wheels should bes the same as on the 100 series, a little bit different with the 20" wheels because they are wider.
Bjørn Erik
How about 18" wheels off of a Sequoia to fit a 100 Series LC? Wheels are showing Toyota 426110C160 Hollander 75156. 5x150 with 60 offset. Ebay compatibility guide says No, but they look like they should
The issue with Tundra and Sequoia wheels for LC's is the caps for the front wheels. Not all caps from Tundra's will fit the LC front hub. It would be good to know which caps work on LC's and which don't. Possibly some covered this prior on another thread. I have seen a number of 100 LC's with black & silver TRD wheels and those caps do fit. The shallow caps on silver Tundra std wheels do not work.
