Nice upgrade, I wonder if it will swap into the 100s.
would be nice, if the 200 diff is proven to be stronger.
Well, the gearing is not correct. However, I believe the 4.7L version of the 200 has a 4.1:1 ratio which would be the same as the '03+ 100's.
Yes, of course, size is an issue for technical and narrow etc trails.
But as an aside, I don't think that "serious off-road" size issues in the US is really much of a factor in the design of the 100 and 200. I'd guess that whatever serious offroad features there are in the US 100s and 200s are mostly because of the potential market overseas. Let's face it, the luxury SUV US market can use 4WD cuz of snow and rain, but it doesn't need skidplates, lockers, etc.
I'm also guessing that the typical "3rd world" or Aussie / S. Africa etc offroading conditions for travellers are not technical rockcrawler types as in Moab, despite what we may picture here. I'd bet that even in the middle of nowhere in Africa, people will still primarily drive on dirt roads, maybe rough roads, but they do not just make a straight line up and down mountains, weaving between trees and rocks. (I'm not talking wheeling enthusiasts, just normal people needing a utility truck.) If only because it's much easier on dirt roads, the roads are on a map hopefully, and that's where people, towns etc are. And the roads are probably wide enough to accommodate trucks.
What I'm trying to say is that I'm thinking that size, departure angles etc are not as critical for 3rd world driving as for rockcrawling trails, and instead sturdiness of hardware, reliability, low needs for sophisticated maintenance etc are more important out there. So large size may not be a serious adverse problem overseas whereas big cargo potential may be very helpful out there OTOH. IOW, we get the large size because that's good both on US freeways and Aussie outback, and we get offroad bits in the US as a freebie courtesy of the same design as overseas market. Maybe this is one reason (comfort another) why we have seen continuous size increases since the 80.
Anyway, I'm curious to see what the nifty offroad design features of the 200 are and how they are improved over the 100, and conjecturing that they may perhaps have been affected by the conditions I'm postulating about above.
I am not talking about how it will do on the trail. I am talking about the attention to detail on the engineering side to make it more durable for harsh conditions.
We will see if Tundra stuff can be used. We just completed this Tundra. Those tires are 37's![]()
ok i'm bored at work and did some reading for the new lx it says it has a new ahc; is this a combo of the kdss and the old ahc system?
what components did you guys use for that tundra?
Time will tell if it can really wheel with the 100, but it will take someone with deep pocketbooks to wheel such a technical marvel and luxury vehicle.
so jim is it similar to the kdss? Last time i was in for service i had time to speak to one of the service guys that helped me before when i had some problems and he said they had no gx's with the kdss sold thru that particular dealership so they had limited experience with it. Have not had any time to see the new lx in person; I took a couple of pics of the1st one they sold. The book seems to suggest it may be a combo of both types?? not sure
The LC200 has KDSS (a seemingly unobtainable option on the GX470) while the LX570 has the X-reas/AHC system. My understanding is the KDSS allows one to disconnect the sway bars for more articulation at the touch of a switch, while on road, you get the benefit of a stiffer sway bar for better cornering. You could get the equivalent on your 100 w/ manual sway bar disconnects (I know they are available as JDM).
The X-REAS on the 4runner uses some kind of cross-linked nitrogen in the shocks (rear left shock X w/ front right, etc.) w/ a nitrogen resevoir to put more pressure on the outside shocks while making a turn. 4Runner owners say it works. Those 4runner sport owners who have upgraded their suspensions to OME have disconnected their XREAS lines. It's easier to make a suspension upgrade w/ the basic SR5 model, but they say you get larger brake rotors/calipers w/ the sport version. If I had to choose between the two, I'd get the KDSS.
