I have a broken master key that I haven't replaced. It hasn't bothered me but looking at Scottm's photo it looks like I could just buy an Ebay key, have it cut, then put my key's remote guts in it. Does this work?
The transponder is in the head of the key, that little plastic portion. If you don't believe it, cut a key and don't program it into the ECU. Try and start the truck and see what happens with the anti-theft system.
you cant just put the transponder close to the ignition, use a cut key and it will start. The transponder has to be within less than a centimeter of a key length before it will start..........believe me on this...
yes there is something either in the dash or the steering column, but i am telling you it has to be a certain distance away...if it is too close or too far away it will not startThere's got to be something in the column that picks up the signal. Utahfj62 installed a remote start and to trick the transponder they just zip tied a key head under the dash.
Has anyone had an ECM from a '99 UZJ100 (P/N 89661-60610) successfully flashed before? Because I bought a reconditioned one, and Toyota couldn't install it because they said it was already paired up to a previous key. However, the place that sold me the ECM says that these ECMs can't be reflashed. I'm not sure what to do...it seems I've been sold a part I can't use.Locksmith Charley's Website - Phoneix Arizona
From his site:
Now if you lose all of your keys or have only a valet key available for only $150.00 I can render your ECM back to its original state ready to accept new transponder keys. This service is available in my shop in Phoenix AZ and mail-in service is available.
If you wish to bring in to my shop or ship your ECM to me, print out the form at http://www.locksmithcharley.com/toyotarelease.doc (Microsoft Word) or
http://www.locksmithcharley.com/toyotarelease.pdf (Adobe Acrobat reader required)
and send the ECM and the completed form to: Locksmith Charley 4024 N. 84th Ln. Phoenix AZ 85037.
The instructions for programming your keys into the flashed ECM may be found in the document at:
http://www.locksmithcharley.com/toyotapostflash.doc (Microsoft Word)
or http://www.locksmithcharley.com/toyotapostflash.pdf (Adobe Acrobat reader required)
