James Kelly said:would putting more air in the tires help with better mileage - and is it worth it?
SINCITY100 said:I run my tires with about 42.5 psi (on highway)...It makes a fairly big difference mpg-wise (between the "normal" 32 psi to the 42.5 that I run) ..probably 2-3 mpg better..
I get 13.5 mpg on virtually every tank of gas with 33" tires and driving my 100 fairly, ...ok..VERY hard
10 mpg does seem a bit on the low side, especially with the stock tires ...
SWUtah said:Your running LT rated tires?? I would say he needs to look at the side wall of his tires and see what his range is for inflation. I have LT AT's on my LC and I run 38 lbs all the way around. I get 17mpg hiway and 15mpg around town on 91 octane. It you get the psi to high the ride gets really rough.
SINCITY100 said:I wasn`t actually telling him to run 42.5 lbs, I was giving my experience with my tires/psi/mpg...Gee, I hope he didnt run out and fill his tires ALL the way up !![]()
A rough ride?...whats that ?![]()
As for range, what is the most common max PSI on L/T`s ? 45-55psi ? ...
my MT/R`s are 65lbs ..
C note said:Wow, you guys are awesome.... so many responses!
Yeah, I will take it in to replace filters and fluids - that's never a bad idea anyway. Also, I'll give it a few more tanks before I smack my forehead again....
Just glad to hear, all things said, I should expect more than 10 mpg; 10 mpg is what our 454 88' Chevy Suburban got pulling a 25' boat!
BTW: I had a very light foot this time around, trying to get the best mpg I could... I'll just fill up those tires (stock size) and give it another go.
Still, I love the cruiser - such a tank! I pulled someone out of a ditch the first day I got it.
Da Hapa said:I don't want to move off topic but that's the complete opposite of my experience on any car/truck I've owned with a relatively high compression ratio.
I know my to be delivered 2006 LX specifies premium grade (91+) fuel.
Jim_Chow said:Aren't all the 100 series LC/LX's spec'd to run on high-octane? Even the V8 4runner is spec'd for high octane, so no gain there. I'm under the impression the 2UZ engine is really designed for high octane...at least if you want to get the advertised hp/torque out of it. Running a higher comp. ratio and high octane is certainly one way carmakers can eek out a little more performance w/o increasing engine displacement. Would one rather have a 5 liter V8 that got a couple less mpg but was designed for regular?
DMX84 said:I’m not positive if using the scan tool will entirely reset the ECU to the factory settings, but would start there after you pull the codes.
