10.4" TESLA-STYLE VERTICAL SCREEN ANDROID NAVIGATION RADIO FOR TOYOTA LAND CRUISER PRADO 2003 - 2009
The two on the right here are what you need to connect, the one on the left isn't used.
The wire which is a bit dark yellow and covered with foam is stock i think, but i am not able to connect it with theharness which comes with android player ,and chines seller is saying my cable is not stock cable.Its not original, so i dont know if he is right,but i had a aftermarket kenwood Navi installed.
The one that goes into a connector with 3 wires? (left one from above pic) If so, it's an OEM and simply not needed. It's what the OEM Navigation uses for reverse and to know if the hand brake is engaged.
If it's a single pin, it's OEM and there should be an OEM connector for it, not on the new harness but in your dash. (if you can't find it, it might have fallen behind something) You can see it in both pics above.
So....if the harness you have won't plug into those two plugs inthe first pic, you definitely have the wrong harness. You also need to remove the OEM ribbon from the AC piece and push in the new ribbon from the new unit.
I have same cables , but chines aftermarket cable cant be connected with this which is sent with android stereo. And when i try to explain them ,i get this reply
I need main power cables to be connected, three climate control cables would be going to stock climate unit with after market ribbon attached,which i have attached already.Chines pdf manual is attached with this message.
Right, what Ella is sending you looks like the climate control connectors. Those shouldn't be an issue since they go right back into reused OEM climate control unit. I think she's confused on that point but does the harness they send have the connections that fit the main two power cables?
No,thats the problem,i cant make her understand this,even i sent her video and pictures.
What is she calling the harness she sent you? They sent me the "lower version" harness (which is what you need) but I think you may have got a different version with those extra bits. Try taking a pic with those two main power connectors and of the entire harness by itself?
And yes , i have selected lower version , 2x64. So i suppose to get lower version cables, but these are with canbus ,JBL amplifier and some other cables.
You're right, definitely not the right harness and it all looks OEM as it's the same as what I have. I guess all you can do it push Ella to send the right harness??
Well, thats the worst side of chines sellers,i am trying to explain her for a week,and she is rather pushing me and saying i have wrong harness ,its not stock .And at the end purchase protection is gonna take her side and close case in there favour.It happen before lets see how long will this take.
It's weird cause I definitely purchased from the same place and they sent me out another harness. (first one was actually right but I had no way of knowing because at that point, there was no instructions)
Skype reply from seller,he said mine are modified or not oem ,damn how to prove him i have oem?
Just found this on a website ,he sent me cables which can be fit here i am sure, do you know what it is?radio ?navi or what?
She sent me wrong cables,and now every thing seems to be working ok,only issue is climate control starts from 25.5 c .
You mean it won't let you go above or below 25.5? Mine are L/R swapped and that's likely a software update fix.
it stats from 25.5 and above til 27 or 27.5 , when i set climate control to auto, i doubt it works, it just starts blowing cold air , how to update the software or firmwire version? does this stereo has updates ?
