Alright...Bought the cruiser with ONLY drivers window and rear passenger(drivers window) working. After the winter I lost the rear passenger window also. The rear windows don't bother me not being useable. But the front passenger window is required because I've recently started using the 80 for search and rescue. I pulled the master switch panel and opened it up to clean up the contacts(they were pretty bad) hoping this would fix the problem but to no avail. Although the drivers window seems to operate better now. After I cleaned up the master I grabbed the previously working rear drivers window and opened it up, contacts looked good and the rocker switch looked pretty new. So I went and pulled the front passenger side switch out and plugged the newer switch in and still nothing. I'm not hearing any motor function in any of the doors when using the master switch. Although, all of the doors lock using the master switch with the exception of the passenger side rear door which only unlocks electrically when I use the passenger side unlock button and not the master...Any quick tips or tricks? I've done research on the subject and did what I've found had the best and easiest results but I think I might have to spend some money to get any of the other windows operating again.
