Hi all
I have a 1974 1.5F transitional engine. (eng no F543191) and have had the crankshaft reground and wish to replace the main bearings, with the new bearings were shims to go under the main bearing caps when i removed the crankshaft there were no shims under the caps. the manual i have is for the 1F engine pre 1974 and states to put the same shims back that were removed during the main bearing cap removal.
Can anyone help? Does this engine require the shims under the main bearing caps.
Mocky
Mocky
