The early MBT Willys and BT3 Bantam 1/4 ton trailers during WWII used a different lunette than later M100 and M416. The M100 was a change from the earlier 1/4 ton started in the early fifties. It was the Bantam BT3 and Willys MBT (plus I understand a few other manufactors who made them in small numbers) that were left all over the world after WWII.
Seeking clarification; rotates in 180* increments, or is free to rotate as the trailer "articulates"?The one pictured is for a M101A1, and the lunette does rotate.........
Then I stand corrected. I wonder if the surplus of M100's dumped in Japan after '53 were the basis for the Type-73.
hum, then this version of the assembly does not do what I'm after. Which is to allow the trailer to "articulate" beyond the limits of the coupling itself, but with some resistance in that rotation so that the trailer can't just flop on it's side willy-nilly.You can loosen it and rotate 180 degrees and tighten the nut. It does not rotate once the nut is tighten. Like Corprin stated this was just to have it trailer level behind different military vehicles.
