1.200" tpf ball joint & tie rod taper reamer
Oceanside, CA (Fire Mountain)
Hi guys-
I posted this near me in the San Diego area but thought i would see if the OC 80 guys might have a line on one too...
Anyone local have a 80 Series TRE reamer?
1.200" TPF BALL JOINT & TIE ROD TAPER REAMER
I need to taper two holes on some steering arms.
(Xkut is all out- on backorder).
Thanks
I've got one- I don't know it will work for your application.
Mike-
Exactly what I'm looking for. I just need to ream two high steer arms from the bottom for 80 TRE's on my 40. Can I borrow it? Obvious responsible for damage (replacement) and whatever loan fee you'd like.
Have You used it? Does it work well? I'll be going the manual route rather than drill press so the damage factor should be close to zero.
Let me know. I can come pick up and drop back off. Im off until Friday.
If you don't want to loan it out I understand too.
Thanks.
I have no issues with loaning it out. I haven't used it yet as I'm collecting parts for a high steer/ 3 link set up. The reamer came with the GM y-link.
I work from home, so when ever is convenient, stop by.
I'll pm you my cell number.
