My wife's '07 Sequoia with about 140,000 miles on it won't start from time to time.
Turn the ignition to start and it "click, click, click"s. And if I try it a couple of more times it slows down like it's killing the battery.
It will then take a jump and starts right up with one of these things, which are amazing - Halo Battery Jump Starter sometimes it takes two tries, but this thing works better than my trickle/fast charge/75A plug in charger/booster.
Before I replace the starter (which is NOT easy on the 4.7, as I'm sure you know. WHO PUTS A STARTER UNDER THE INTAKE MANIFOLD!!!) I want to run through what I've done, get your thoughts on what else it could be, and try the easy stuff first.
I've -
Thoughts?
I've -
- cleaned the batter terminals and connections
- checked the starter relay (it's good)
Thoughts?
