Hi all,
A week or so ago I replaced the globes+fluid on my '06 LX470. After replacing the globes I mistimed a reservoir refill, the tank drew down to empty, and the AHC switched itself "OFF". I topped up, restarted the car, and was pleased to find that fluid drew down into the system, the car equalized, and I could move between L/N/H with ease — and I had 12 gradations on the side! The ride was much smoother, and I figured all was good to go.
However, over the next few days I found I had trouble moving through L/N/H — it would take a very long time to do anything. Eventually I landed back at N, and now if I try to raise or lower, the light will flash forever, and the car will not raise/lower. I can (sometimes) hear a stuttering sound, not from the pump but more from under the car.
I ran techstream to take a look and was not able to engage the motor/pump – it would switch to OFF and stay there. I had error code, C1763 - "Oil pressure for pump motor abnormal." Cleared that, tried to engage again, same thing. The code didn't reappear but I'm still unable to engage anything. All of my pressure values were flat 0.0, too.
I'm sure there's air trapped somewhere. I want to bleed the system, but am afraid that I'll drain down to L and then the pump will continue not to engage, and I'll be stuck down there.
From reading around I also suspect my pump attenuator might have the suspected air, and I'll need to bleed that... but I can't find a clear description of how to do this.
Any ideas here?
Any ideas here?
