02 sensor circuit malfunction (bank 1 sensor 2)
I did a search on this fault and didn't find anything. I just pulled this using torque. anyone know where this sensor and is it easily replaceable ?
Thanks
Should be the O2 downstream of the cat, which is underneath the truck passenger side below the rear seating area in the exhaust pipe. It is about a 10 minute job with hand tools and no need to jack the truck (not sure if running boards are in the way? I don't have them).
If you're replacing it, replace it with a Denso sensor specific to the truck, makes plugging it in easier.
Thanks, any idea where I can find the denso part numbers .....I might as well replace them both
I have had the same code for two years, 2 new sets of O2 sensors hasnt fixed it. I think it's either going to be a wiring issue or a computer issue. Haven't bothered to figure it out.
Oh I hopethat isnt the case for me....wont pass inspection
you are a better mechanic than I.......took me 10 minutes to get under the truck(bad back) the nuts were rusted so bad couldnt get a wrench on them......ugh
