02 LC Suspension hardwares part numbers for upcoming Black Friday sales
Los Angeles
Hello, I got my wish list for my 2002 LC with 200k mi. Suspension still feeling ok but like to get the parts now as just a matter of time. Anyone already done it recently and got the necessary nuts and bolts for the suspension items? Thanks !
Parts I’ll be ordering:
Front upper control arm R 48610-60030
Front upper control arm L 48630-60010
Front Lower control arm R 48620-60010
Front Lower control arm L 48640-60010
Front shocks RL 48511-69585
Rack n Pinion 44250-60050
CV axle 43430-60040
CV axle 43430-60040
Outer Tie rods? Sway bar bushings and “giblets”?
Oh yeah outer tie rods! I recently replaced all the sway bar bushings and weld repair the right AC drain rusty bracket. Btw the rack and pinion assembly does not come with he tie rods? Thanks
I'd use partsouq.com and enter your VIN in the website. You can then pull up all the most detailed part diagrams to pull the part numbers.
Just off the top of my head, I'd imagine you want the bushings that are installed in frame since the front lower control arm only has one integrated bushing built into it. So those diagrams will keep you organized on what is what.
Word of advice. Keep an excel file to give a description for any hardware you're buying. All the hardware starts to look the same when it arrives and having to go back to confirm what each part number is for is a pain.
Only inner tie rod ends.
Took me a long time playing with Toyota site, figure there got to be a better way. Thank you!
If you are buying overseas don't forget the tariffs. I'm not sure how it's calculated and how much.
