01 LX - C1776 code
oh I could cancel order if needed, I assume AISIN was OEM quality. Not the case?
I suspect Aisin is fine. I believe they're the OEM supplier for Toyota/Lexus on that part. Aisin (or Denso) parts are not always identical to the genuine Toyota/Lexus, but generally close enough that you could say they're the same.
For the AHC sensors I don't think I've heard of Aisin being a problem. To the contrary, I think every single person that mentioned they had an aftermarket (non-Aisin) AHC sensor had problems. I'm not using hyperbole when I say aftermarket AHC sensors are worth nothing.
Aisin sensors on, it's amazing how much easier it was to calibrate the system. My sensor readings are rock steady now, even mirroring each other during lo and hi. Took me all of 5 minutes to get the sensors zeroed out after install. I'm not sure if this will fix the wheel speed sensor or not, but I suspect it will. Thanks for the help again. I'll report back in a few weeks on the wheel speed sensor.
Awesome. If you can't return those aftermarket sensors for a refund, I'll pay for shipping to me so I can test them out. I'd love to see WTF they're doing with those sensors to make them perform so poorly.
Sure, dm me your address.
