"0"compression in #4!
Help! My F engine was running rough and blowing some oil out of the home made dipstick, so I ran a compression check and found all well except "0" compression in the #4 cyl. After pulling the engine and removing the head and #4 piston, I cannot figure what the problem was.
1) The head was recently planed and a new head gasket was installed after the head gasket blew out between #3 and #4. The gasket surface on the block seems to be true.
2) The valves seem to be seating well. There is one minute pock on the valve and seat, from some long gone debris.
3) The piston rings are out of spec. When measuring the end gap the .0200 inch would fit in all rings. The maximum was .0160 or so (I don't have book with me now.) Is this a big enough difference to cause a Zero reading on the compression checker?
4) The compression checker fit properly into the spark plug hole, so I believe the reading was accurate.
Look around the deck of the block, did it look like the gasket was sealing? It probably was since I assume all other cylinders (3&5) were testing fine.
Since you have the head off it might be easier to take it to a machin shop and check the head out, they can vacuum check the exhaust and intake port to see if the valves are seating, and then check the head to be sure its straigh and has no cracks.
You should also take a straight edge on the block and check for true with feeler guages. check at several angles esp around that cylinder.
Next time, or when you get the hed back on and it still is zero, run a full leak check with air and listen for where its comming from (cylinder next to it, intake, exhaust, radiator, dip stick) this will isolate where to start checking.
Good luck.
Should have done a leakdown test prior to pulling the head.....but, oil blowing out of the dipstick=compression into the crankcase=rings or broke piston etc.
Butch
Pretty hard to believe that a cylinder would have 0 compression if the valves and piston were OK. Even with no rings, it would make some compression. You could do an Okie leak test to see if the rings on #4 are worse than the other cylinders. Turn the engine so that #4 is half way down and then pour 1/4 cup of paint thinner into the cylinder and on the other cylinder that is half way for comparison. If the pain thinner leaks ut of #4 faster than any other cylinder, the rings are probably not so good. Do the same thing with the head to see if the valves seal well on their seats.
now that's Okie
lol
Pin_Head said:
That's right, because it sure beats putting the head back on just to find out whether the rings and valves are shot or not.
I have never seen anything else pressurize the crankcase, other than rings/piston.........he has some stout blow by to push the dipstick out...
