Just starting work on my fairly stock machine and before i go to doing a hack job on the wiring, i would like some help. My hazard lights work perfectly but there are no turn signals. Could anyone point me in the right direction to track down problem? Thanks.
Hi Rocknroll, could be a problem at your turn lever switch. Pull off the steering column cowling and check the contacts etc at the base of the lever. Failing that try to find the prob with a circuit tester....but....
Before you go fiddling with those old turn signals I have a suggestion about customising/personalising your rig. Track down some turn signal light assemblies off a 70-75 series cruiser. I don't think the 70's came out in the US (correct me if I'm wrong!). The lights are pretty light weight so freighting them from Australia (dime-a-dozen over here and you can get them new or used!) won't cost the earth.
Ok, so you get the 70 series units, rip off the 40 series lights, patch the hole in the guard and mount the new ones. The 70 series unit fits perfectly on the bonnet support panel in the angle where the front of the guard meets the bonnet support....
Like so. You get a nice clean line on your guard and your truck looks a little different from every one elses! It the little details that count. The 70 series indicator lights come with either a black back and surround or in the last couple of years they have come out in a chrome finish - just be careful not to put too much chrome on your rig or it may turn into a jeep!!!
Circuit tester is the best tool to help you track down the problem. You can start at the signal light or the swicth either way. Ruling out burn out bulbs or corroded or bent up contacts in the lights themself is a quick starting point. If you start at the light see if you are getting juice in the bulb socket with the circuit tester if you are then you probably have a issue with your bulbs or a bad contact. If you do not have juice in the socket go to the wires at the back of the socket.....keep going until you find where you do have power and then figure out what is stopping the power from getting to the lights. If it is in the switch on the steering column you may be able to temp repair it or just get a new one. I got one from CCOT and it works fine. The contacts in my switch were worn down and actually had a crack in the solder which I was able to repair but it would not have lasted long before breaking again. You may also have a issue with your blinker unit. You can get a new one of these at any auto parts but it of course will not be like the stock one. But you can wire it into the circuit just like the stock one. I had to get a extra loud one so I could hear it just a little. Good luck
The freight would prob cost less than the unit. If you really want me to look into it send me a PM. I could track down a parts supplier for you and you could go direct through them and I'm sure they could ship it too you direct
