- Location
- United States
Thinking of selling my 1997 FZJ80 "Collector's Edition" after many years of faithful service. I have spent a small fortune on all of the goodies and want it to go to a good home. First, I'm wondering what a fair price is but I am of course open to offers. Following are the specs:
Year: 1997 FZJ80 - Desert Dune - Leather Interior - Loaded
Mileage: 108,900
Aftermarket Equipment:
*Complete Old Man Emu 2.5inch suspension lift (Heavy front springs, medium rear springs (set of heavy rear springs included), shocks (all shocks just 6 months old), spring packers and steering stabilizer)
Old Man Emu Caster Correction Kit
Slee Rear weld-in upper control arms
Slee Adjustable weld-in panhard rods
Slee Heavy Duty Rear Control Arms
Marlin Crawler Heavy Duty Drag Link and Tie Rod and HD rod ends
Stainless steel extended brake lines
Swaybar drop brackets Front/Rear
Rear Bumpstop Extensions
*Slee Rear Bumper with Swing-Out Tire Carrier
*Diff Switch and Pin 7 Mod
*ARB Winch Bull-Bar
*Slee AC dryer skid plate
*African Outback Drawers w/fridge tie down and water tank
*Hanna Quality Custom Rock Sliders w/Cat protection
*Warn M12,000 Winch
*Dual Battery System: Two Optima Yellow Top Deep Cycle Batteries, Wrangler NW 200 AMP Solenoid w/interior switch, 1/0 Gauge Cable through frame to rear of vehicle, HD Fuse Panel in rear to two auxullary lights also in rear, Painless Wiring Fuse Panel in engine compartment.
*PIAA Auxiliary Fog Lights
*Marlin Crawler Front Diff Guard
*Rear Aussie Locker – 6 months old
*Cobra CB (wired for front and rear antenaes)
*Slee Off Road Heavy Duty Transfer Case Skid Plate
*Slee Off Road High Power headlight wiring harness
*285/75R-16 BFGoodrich All Terrain TA/KO tires, less than 10K miles, matching spare on full size matching aluminum rim
*OEM Center Differential Lock Switch
*OEM Dash Cup Holder
*OEM Hand Throttle
*Four OEM Light Switches
*ARB Front Antennae Mount
*Stainless Fire Extinguisher in rear
*800 Watt Inverter
***There are things I've probably forgotten as well***
Maintenance:
I have all receipts for parts and maintenance
60,000 Mile service completed @ Toyota Dealership
Front Birf repack completed @ 100,000 Miles
New "Improved Design" Head Gasket and Cylinder heads @ 77K
All new front and rear rotors
New Fuel Pressure Regulator
New parking brake pads
You can email me @ mattheworton@earthlink.net
Thank you -
Mileage: 108,900
*ARB Winch Bull-Bar
*Warn M12,000 Winch
*OEM Hand Throttle
*800 Watt Inverter
Maintenance:
Thank you -
Heather
