FJ25 body tub $300
FJ25 body tub no real rust but has some holes cut in it. If you are doing a 10 point restore then this is not for you. I am in SO CAL and can send some picts via email. Also have some seat frames and centered rear dif available.
kevin
it is not a hard top model, and it has the door opening that looks like a CJ5. as it is raining right now i may be able to post pictures on saturday if i do not sell it to a local guy.
fj25 tub fenders notincluded.webpfenders are not included with the tub . i do not have the grill, the hood is included.
https://forum.ih8mud.com/attachment.php?attachmentid=65403&stc=1&d=1144043228
Kevin . . .
At least on my computer, your photo link didn't bow up the picture any larger than the one you posted. :frown: Could you post it a little bit bigger? Thanks. :)
This a early FJ40 soft top not a FJ25. The gas fill opening is in the wrong spot for a FJ25 plus the opening for the battery in the tool box is not there. It uses all the same soft top parts as a FJ25 but it's a FJ40. My guess is a 1962.
John
:doh: I didn't even notice that when I posted Kevin's pictures. (Some trained observer I am. :rolleyes: )
The square rear wheel openings should've been my first clue.
SAquare wheel well openings have been cut that way.
Whatcha want for it?
Just curious what the VIN starts with, but the battery box, column shift opening and gas fill says 40, stranger things exist though......
40 or 25 it's still better than 99% of the tubs you see around here. :D
soon to be on its way to the crusher, please act fast to save this nearly rust free tub. and yes i have an fj-25 vin tag that came with the tub, some people here think that the tub might be an early FJ40. I also have a centered rear diff , reat frames that will go with it.
