Last week while travelling for work I suddenly started to get a low groan and some bad vibrations.
It came on all of a sudden and it took me a bit to figure it out. It seemed to be coming from the heater fan. I called Dan for a new one and it will arrive on Wednesday.
This morning I pulled the fan only to find it full of what looks like pink insulation. Pleasantly surprised that it was a simple fix I decided to remove the cage and wash out the 10 years of dirt on it before replacing the fan.
I removed the retainer clamp but the cage wouldn't budge. So I decided a little persuasion with a hammer was in order and tapped out the shaft. What I didn't realise is that there is a sort of locking tab on the cage that holds it in position on the shaft and the clamp is only a secondary measure to ensure the locking tab doesn't fail. Once the cage was off I realised that not only did I remove the cage but drove the amateur out the rear of the fan housing.
Easy diagnosis, unfortunately the patient died.
If you have diminished heating of cooling you might look into cleaning the cage as mine was fairly dirty. The fan cover comes off with 2 Philips screws and the fan itself is held in with 3 slotted torx screws. About 5 minutes to remove from the housing.
You win some, you loose some and then there are those times you're just a F'n idiot!
