Hydraulic Cylinders are back from White Post
Carolina, RI
Website
www.yankeetoys.org
And boy they sure are purdy :D
Cleaned and sleeved with all new hardware, now with a lifetime waranty. Not the cheapest way to go, but definitely the best!
They put them together with new hardware? Did you supply parts or did you put 'em together....Just curious about the pistons in the masters, as in who had new parts...Oh, btw, what is the inside diameter of a stock 25 clutch slave cyl? I have a mess of these things lying around (certainly not on a rig) and I need to sort them out....
Sean, there is a thread somewhere about some NAPA fittings to go from 9mm to 10mm. I read that the P/N is BK 6415023, and that they are about $6.50 each. I never used them, so Ihave no idea how good they are.
Could you post contact info for the wizzards of such wonderous repairs? I would love to not have to junk my originals off the '62.
So I called Billy up to see if he can restore a 2 line master for my '64, but to be installed with-out a booster. He tells me that they can only restore the master exactly like it was manufactured. I say that this is fine, but that I need the push rod from the '64 installed in the dual (or a similar rod) as it will not be attached to a master, to which he tells me that they can't do it...am I missing something here? Shouldn't this be an easy thing to do?
Theyre doing that for liability reasons. The push rod just slides out doesnt it? Just do the swap ands then send it out.
