I bought trans and -case off some guy a while back claiming it came out of an 85 with the better split case, but how can one be certain? Is there anyway to tell? And is there really that much difference in early split cases vs. later ones?
cruiseroutfit said:There are some differences between the 34 & 38, gear ratio, bearing use, etc...
Yeah Kurt it does have the cast spacer between...cruiseroutfit said:Measure the idler shaft that sticks out the back of the transfer case, you should be able to get a set of calipers on it. 34mm is the early case, 38mm is the later.
Does it have an ~4" cast adapter/spacer between the actual transmission & transfer case?
There are some differences between the 34 & 34, gear ratio, bearing use, etc...
theMule said:Yeah Kurt it does have the cast spacer between...
