caliper/brake question
Tucson AZ
Well, the inevitable happened. During my last oil change I noticed a small drip of diff oil coming off one of the large nuts below my DS birf. I have all the parts as I was planning on this being PM and not required maintenance. I have a local helper (MaddBaggins) to assist and the lovely search button as well.
I just so happened to notice that my front brakes need attention too. They are squealing. I have also noticed that they catch and squeal after the letting up on the brakes. Applying the brake does away with this catching.
My questions are:
1. Do I need new rotors since a waited until they made noise?
2. Does the catching indicate a caliper rebuild is necessary?
3. Is it crazy to think I can do both birfs and a caliper rebuild in one day?
If I go with new front rotors I can upgrade to 100 series brake pads, but the calipers would cost me some time. Any suggestions would be welcome.
Thanks,
Ross
GeoRoss said:
Well, the inevitable happened. During my last oil change I noticed a small drip of diff oil coming off one of the large nut below my DS birf. I have all the part as I was planning on this being PM and not required maintenance. I have a local helper (MaddBaggins) to assist and the lovely search button as well.
I just so happened to notice that my front brakes need attention too. They are squealing. I have also noticed that they catch, squeal after the letting up on the brake. Applying the brake does away with this catching.
My questions are:
Thanks,
Ross
Hey Ross,
You may not need new rotors if the squealing you hear is due to the wear indicators and you have no "pulsing" through the brake pedal that would suggest warped rotors.
You can measure the thickness of the rotors and determine if they can be turned down enough to "true them" if they are warped, or just to provide a good surface to bed your new pads on.
Conventional wisdom here however is: That turning down the rotors makes it more likely that they will warp again in the future and most of us choose to just replace with new ones. This would also be the fastest way to get your Cruiser up and going again.
I did a compete front axle service when I did mine... and with no other help I completed it in about 10 hrs. That was with the benefit of air tools, a parts washer, and all of the vehicle specific tools necessary.
Personally, I would evaluate the calipers later. They are easy to remove and unless you know they are sticking I would put them back on with nothing other than a good cleaning and lubricating the the pins.
I think it would be pressing it to try to do both, but if one or both of you have done this before it might be possible.
I would suggest writing down all of the torque figures prior to starting.
I feel confident that the next time I do mine (or someone Else's) that I could shave a couple of hours off the time required.
Good luck to you guys, and buy LOTS of paper towels...I mean LOTS!
GeoRoss,
Toss the Ipod on and measure your rotors - they're probably fine.
"Catching" is a tad vague - can you provide more details?
Crazy? No, but the first time you do this plan on 2 days. Shouldn't take more than a solid day for both, but take your time and allow for plenty of #6 breaks.
Thanks for the responses,
The 'squealing' noise is from the wear indicators (I think) and the 'catching' is only noticed as this noise continues after letting up on the brakes. This noise only goes away after a sharp/hard application of the brakes. I only have an n=1 on this as it has only happened once, the last time I drove the LC.
The rotors don't feel warped, no pulsating.
I guess I will call in an order for the rotors, just so I can talk to Dan and upgrade to 100 series pads.
I will order the caliper rebuild kit and address later (within the next week).
I will bring plenty of #6, but we will be starting early (beer+am=:eek:). MaddBaggins has done this before so as long as I can keep him sober :D his experience should help things go smoothly and quickly.
I will be visiting Costco tomorrow and will be getting a crap load of paper towels.
And Junk:flipoff2:, the iPod is doing fine. I've been going over some data and I had the iPod running at 17,867ft :bounce: :bounce:. It has been hanging on a few songs, so I reformatted it and reloaded. All is well w/ the music now. On a sad note, the GI tract is still all askew but I am back doing field work in 105 temps. I may have to visit the doctor if the runs continue. Something for you to consider for your upcoming trip, take lots of Immodium, TP and wipes.
Ross
If in looking at the pads on the front brakes you notice tapering from top to bottom, or the thickness of the pads one side is thicker then the other. If the pistons are hard to squeeze back into the caliper. then you may be sticking or hard rings around the pistons. This could create some of what you hear also. If installing the 100 series pads into the alread exisitng problems of the sticking pistons you will have faster wear and greater heat on the rotor, thus leading to faster warping of the rotor.
IMHO, you would be better off fixing the calipers if you have a problem before you go to a pad with more surface area. Your truck would also brake better with the calipers fixed properly, less warping of the rotors as well if you think the calipers need fixing, then take the time to fix them. I beleive either Napa or Carquest carry rebuilt ones that are good quailty thus saving alot of time(just do not ask Junk to help you, brakes are not his forte). good luck later robbie
I'll replace the pads and check for unusual wear. Hopefully I can tackle the fronts today/tomorrow so if I need new front rotors I can order them from Dan in time to install this weekend during the front axle job this weekend. I was considering upgrading to 100 series front pads, but there doesn't seem to be a consensus on the necessity of grinding some part of them for them to fit. I am not entirely clear on what needs to be sanded/grounded off. Is it just a light sanding of the pad surface itself like some of the post's seem to indicate or for some part of the pad's frame?
Here is a question, how does one measure the 'run out' of the disc? Is this just checking for even wear across the disc? I'm not too stupid/inexperienced to understand thickness, but haven't a clue about run out.
I will check the calipers for sticking, and address them with a rebuild the following weekend if needed and if not needed sometime in the indefinate future. I am hoping to coincided the caliper rebuild with a complete flushing of the brake fluid and the proactive addtion of extended brake lines so I only have to bleed the brakes once.
Thanks
Ross
GeoRoss,
Have all part ready and on hand, return later if not needed.
When I did my front axle I had rotors on hand as my brakes had been pulsing slightly.
When I removed the hub the rotors appeared to fine so I left them on.
As for the squeal, the actual indicators squeal is non stop and not just when you brake when the pads are really worn. If the caliper actually digs into the disc you will know it by the grinding feel.
When I put all mine back together with new pads, bleed all five points (2 front, 2back,lspv) and used a generous amount of brake cleaner on both surfaces of both front disks.
All pulsing was gone with orginal rotor. I got lucky.
You may want to run them by a pro to make sure the rotors are not warped.
I just replaced the rear pads on my 80 yesterday.
I was getting some squeeling whilst braking, so I had a good idea that they were due.:idea: Upon removing the pads, I found that I had about 2mm to 4mm of material left on each pad.
I did notice that there was a little uneven wear on the pads. How much is considered too much? At most, the difference was 2mm. Not enough to worry about? I'm thinking no...but...since this thread's here...I thought I'd ask.
There will always be a little uneven wear, so no worries. It's up to the owner to accept or not accept that the wear of one pad too close to the metal will force a brake pad replacement before others need replacing. I wouldn't sweat that amount, personally. When you DO replace the pads, do an inordinately good job cleaning the sliding pins and dabbing a bit of brake lube on them so things move easily.
BTW I'm assuming this is comparing L and R pads in a single caliper - some unevenness is OK. This is also true among calipers on the same axle and also between F/R axles. Perfectly even wear is elusive but is reflective of a perfectly balanced system in some ways.
DougM
Thanks for the info Doug.
Yes, I was comparing like pads -- same caliper.
Sometimes a bit of latent OCD comes out and I feel the need to have everything balanced ;)
OCD is a good thing on mechanical things. They don't complain you're being too picky....
DougM
FWIT, I was rebuiding my front and rear calipers this past weekend and noted that a few of the pistons were indeed sticking despite the apparend pretty-even wear. My original reason for rebuilding was that I was getting spongy pedal syndrome and felt it might be due to a sticking caliper...
Anyway, my point is that I think rebuilding calipers on any truck with say greater than 100K is not a bad idea...it's better than waiting until you have a real problem, and some in-between kind of problems are not very apparent just by inspecting the pads. The cost is minimal (about $40 all around) and is well worth the effort IMO.
The only complaint I have is that the FSM does not describe the process at all. The fronts are pretty easy, but the rears are real fun--the only way I found to get it all back together right was to put the boot on first, then work the piston into the caliper while trying to pull the boot up around it. A real PIA; there must be an easier way that I just didn't think of... :rolleyes:
Problem solved (I think?)
I tore into the front brakes this morning. The DS was missing the anti-rattle spring, the big one that resembles a treble clef. I located one at the local dealership. The anti-rattle spring was in place on the PS. I was thinking that the noise was from the DS front.
The non-OEM pads and all but non-existant shims were ok on the wear department, with even wear and could problably go for awhile. Disc thickness was good. Don't know about the run out as I don't really know how to measure that or what it is.
I had some new 80 OEM pads and shims, put it all together and no more noise or catching. I did notice that this spring does keep everthing in there tight. As the noise was new, I suspect it fell out as suggested by Beowulf in a separate thread. I gues the pads were loose enough to make the noise and occasionally stick.
The calipers were in good shape. I have new rotors and 100 series pad coming and may install with the front axle job this weekend. The only carnage was one of my center caps falling off while driving. As I watched its trajectory across the road, another car killed it. I'll be calling some salvage yards for a new one I guess.
Thanks for the help.
Ross
