Gold Finger said:A wider track theoreticaly allows more articulation and softer springing.
RavenTai said:I had a suspicion that 1/2" would not help much with tip, I tried to brush up on my trig and did some rough math. But finally decided to use a trig calculator I wish I had looked for a calculator before I spent an hour trying to figure out trig again.
it is dark so I did not go and measure my truck, but the NCF calls out tread of 63" (distance between tires), add 275mm x2= 21.6" for a total outside to outside somewhere around 84.6" assuming the center of gravity is centered (it probably is not, but we are interested in tip both ways so this is an average) distance along the ground from CG to outside corner of the tire is 42.3", with a half inch spacer that would be 42.8"
here is where a WAG gets added to rough math, I am guessing the CG is about 30" off the ground, I have no idea is this is even close but is the # I used. Since we are looking for a relative difference between stock and with spacer, not truly what angle the truck will tip at I think this is close enough for these purposes..
Makes for a hypotenuse of (distance from outside corner of tire to CG as the crow flies)
51.8" stock
52.2 with 1/2" spacer,
And an angle of
35.345° stock
35.028° with ½” spacer
Subtract those from 90° and you can therotically traverse
54.655° stock
54.972° with 1/2” spacer
without tipping over
A difference of .3°, Not worth the $ IMO, more accurate CG-height and width measurements will change this # but since the width difference is set at .5” not by a whole lot, there are other variables I cannot calculate, like how the tire and suspension will move differently with the spacer.
Some other downsides, a spacer will move the center of the tire away from the knuckle increasing the leverage and load on the trunion bearings, also changes the arc of the turn possibly throwing off toe in a turn, both are minor differences but both negatives for a minor gain,
A better solution to getting that half inch may be to get wider tires, a 305mm tire is 12” the stock 275mm tires are 10.82 a difference of 1.18” half of witch (just over half an inch) goes to making the track wider, but the center of the tire stays in the same place, no effect on trunion loads nor toe
Kalawang said:I dearly wish I had paid more attention to Math.
I have no idea of what degree of offset my rims have, they are 10" rims R15 and I'm using 33x12.5 R15 M/T Yokos. They made my LC 3 or 4 " wider at the tire than my previous set, 315x75 R16 M/T Yokos on 0 offset 9" rims.
Kalawang
RavenTai said:distance along the ground from CG to outside corner of the tire is 42.3", with a half inch spacer that would be 42.8"
