Angry 3FE
Seattle
So my 91 FJ-80 with 159,000 has been running pretty rough lately (shakes when under load) and has been getting poor mileage (<10mpg).
Took it in to the mechanic who said the Left O2 sensor is dead, EGR is stuck, cap and rotor are worn, the 3 month old platinum plugs that NAPA told me to use were wrong (so I need regular old NGKs), and my ignition wires are not sitting tight on my plugs. Also said that my compression is wonky #1-135, #2-115, #3-140, #4-135, #5-125, #6-146. My Leak-Down was as follows #1- 60%, #2-55%, #3-35%, #4-45%, #5-65%, #6-45%. They said #5 is leaking past the rings.
They say for $1100 they can make it run "as good as it will get" barring a rebuild. This service includes both O2 sensors, EGR, cap and rotor, plugs, wires, and valve adjustment. I told them I can do it all (except the adjustment) and just to throw some new plugs in since they had them out already. This will cost me $180 in parts and a half day or so.
Aside from replacing the left O2 sensor (the bad one), the EGR, the plugs, wires, cap, and rotor does anyone have any thoughts on how to get this thing running better....besides a rebuild.
Any way to bring the compression back up in #1,#2 and #5?
How about that "seafoam" junk?
Or....with the numbers you see above, is this thing dead?
Thanks all,
Take care:cheers:
Have you owned it a long time, or just get it? Do you know if it ever had the valves adjusted, frequency of oil changes, etc?
At 159,000 miles your 3FE should just about be getting broken in; I would be surprised if your rings are worn, so the low compression figures could be at least partly from poorly adjusted valves, assuming they aren't burned up from being way out of adjustment.
Take the plugs back to NAPA and ask for the correct replacements free; if the plug wires are original get a new OEM set.
But going back to what the mechanic said; that the wires are not sitting down on the plugs?? That sounds odd, ie, you just push them down and they snap on the plug; unless he was saying the connectors were damaged??
IME the valves should be adjusted; ?maybe never done, or done incorrectly; some mechanics guess at specs based on their experiences with other Toyota engines and do not consult the factory manual. It is hard to find someone who will do it correctly(IME); it is a dirty back-aching job, and the FSM says to adjust them hot.
I'm not going to get into the flush/clean or not to flush/clean debate. But a severely sludged engine can have stuck rings; not that common nowadays, but can happen if oil changes were terribly neglected. Some advise to just change the oil a few times in a row with short intervals, others say use some product to clean it up internally. You decide.
You could try adding something to the gas to clean the injectors (big debate here also) NAPA carries the BG44K; pricey at about $14 a can, or Chevron Techron; neither will hurt anything if used as directed. My opinion, the BG44K.
And don't forget the air filter; that engine seems overly sensitive to a dirty air filter, IME; everytime I thought mine needed a tune up, hard starting, etc; all it was was a dirty air filter. Also, check all the air/vacuum hoses for cracks, loose connections, etc.
My suggestion is to do all you can yourself using OEM parts and then see where you are after that. Definitely have the valves adjusted at some point by someone you can trust to do it by the Toyota book.
You can get a discount if you order everything from CruiserDan at American Toyota, he knows all the parts you will need.
Good luck, and post your results.
g
Monkeyboy... you don't live in Seattle, do you? I just picked up my FJ62 from a mechanic and he was just telling me he broke some bad news to another 3FE owner an hour prior...
most of that stuff u can do ur self. i'd replace with oem parts or at least high quality after market stuff.... i think man a fre is now selling the dui kit for the 3fe. if u cant get the valves done ur self find a good mechanic to do it. mine needed that done when i bought it last year. makes a world of difference
I agree with the above boys.
cept the bosh platimums, I ran 3 different sets in my 92 for up to 15k per set, no issues,
The running like s*** is likely caused by the neglected egr system leaking, the top side diaphragm is in the vacuum circuit and an air leak there will cause your issues. also if the shop where you have the truck does not know the 3FE well the intake boots/tubes like to split on the lower side, This will also cause you greif.
My advice,
Buy a fsm and adjust your valves, It is actually pretty easy once you figure it out, Tips would be to have the air cleaner loose, run till warm and dig in, It will be easier to pull the valve cover if you loosen the coolant hard lines off the block and pull the wiring loom on the firewall off of its clip and up slightly, order a new valve cover gasket, They are cheap.
Unless you bought the s***ty 4 prong death plugs leave em be, start with the egr and modulator, both intake boots from C Dan or your local dealer. order a few lengths of vacuum hose as well as it is odd sized and just good to have around, IF you EGR is clogged up likely the lines to it are as well. just replace them, They are cheap.
See how it is running.
Then replace BOTH of the 02 sensors, Do not use the AM ones, just bite the bullet and get good ones.
Then get a cap and rotor and wires and change them.
The big ones are the valves and the egr/vacuum s***. Unless you have lots of $$$ to burn get a decent hand set of tools, A fsm and get to know your truck.
Dave
Monkeyboy,
My first question would be...How the hell could this guy perform a compression test if the valves were not adjusted to factory spec first????? The valves loosen up over time on this motor and will not seal correctly. The FSM calls for a valve adjustment every 15K miles.
Heed what others have said. Contact C-Dan or John Hocker or any of the other parts gurus available to you. If the previous history of this vehicle is somewhat unknown, below is a list of things I would replace. Some of this stuff will make a very dramatic difference in the way a 3FE runs and some is simple PM on a 16 year old vehicle.
Replace all ignition components with OEM parts. Replace both O2 sensors, not just one.
The diaphragms in the EGR valve and EGR modulator dry out over the years and should be replaced as PM. The hard vacuum lines are most probably clogged with carbon and fragmented EGR parts. Clear these out one at a time. Replace the old soft vacuum lines with new, again one at a time.
Replace the fuel pressure regulator with OEM.
Replace the fuel pump pre-filter and all associated rubber bits with new.
Replace your fuel filter with new.
Replace the fan clutch
Monkeyboy; let us know how it turns out, ie: after each repair or each group of repairs. I'm most interested in the EGR fixes and the valve adjustment. Would be nice to see which one of those helped, or not ie: do those separately and see what you got. Or, if it was something else, or just everything discussed above.
Thanks
g
Thanks
g
Sorry it took me so long to get back. Been sick.
So I got NGK plugs in, replaced the ignition wires, cap and rotor, cleaned the air filter and ran the seafoam.
After the seafoam it smoked for about 20 minutes. :eek: After that I drove it down to get some gas. Seems to run a bit better, likely due to the wires, cap rotor, air filter and plugs. Gas mileage seems a bit better now too.
I was going to replace the O2 sensor but the heatshield is all rusted up, I tried to loosen it up and got one bolt off and broke two others before I quit. May have to cut the damn thing off now and but a new one to replace.
Also did not get to the EGR.
Next step is to throw the u-joints on the rear line. That should stop the shaking. Then the fuel filter and an oil change. So there you have it, not very informative.
Will try to let you know the results post EGR and O2 sensors.
Thanks for all the help!
Sounds like you are making progress. SEARS is having a lot of sales; starts on Friday; they have a set of the easy outs used to pull out rounded off nuts and bolts,etc. Slee Off-Road should have new 02 bungs if yours are messed up. You could now try the BG44K (NAPA) in your gas. Keep us up to date.
U joint
Replaced the rear joint on the front driveline last weekend.
WOW. The needle bearings were missing from 2 sides and the caps on those were cracked/broken. Put the new one in and it runs nice and smooth now. No more squeek when I accelerate and no more ping when I shift.
Hoping to cut the heat shield off this weekend to replace the Left o2 sensor.
I'd replace them both.
Replacing just one is like replacing only three of the sparkplugs because hey, the other three didn't look too bad.
Yeah but sparkplugs are like 3 bucks! I know it is weak, but I am on a budget and have to fix it as it breaks right now. Sad but true.
MB; were you getting some vibration from the front on acceleration (along with the squeeks and creeks)? If so, did the vibrations smooth out after the new U-joint? Why just replace one? ie: did you check for play before you pulled the driveshaft down and the rear joint had slack?? Was the other joint fine, or didn't you take it apart?
I was getting a lot of vibration, and it would squeek til about 20mph. Also I would get a big "ping" when shifting park-rev, rev-drive, etc.
All symptoms stopped after the replacement.
The reason I only did one was a time issue more than anything else, I ran out of hours in the day. I have also been doing all my repairs with a nice case of bronchitis...trying not to spend too much time out on the driveway for fear of pneumonia. I checked the rear shaft while it was on the truck and it seemed solid. And the front U-joint on the front shaft was also solid. I regreased the others and decided it was good for the time being.
Again I know I must seem like a huge slackass, but I am just trying to whittle down the problems one by one, part by part. Once I get it running well, and once I get some more time and money I will start replacing the "should be replaced" parts. For now the "have to be replaced" parts are getting my attention.
:cheers:
MB; so you had the noises and the vibration, but grabbing ahold of the front driveshaft and twisting (tires on the ground) no unusual slack, correct? But when you pulled down the shaft it was readily apparent that the rear U-joint was the culprit,ie: before you pulled the joint apart; also correct?
Don't worry about anyone thinking you're slacker (you're not) you are sick and it is cold outside. Bronchitis often starts from a virus (cold/flu) then at least partly due to the microscopic damage done to the lining of the bronchial tree by the virus, bacteria can then take hold and the process continues or worsens. See a doc to see if you need a chest xray, antibiotics, etc; (Disclaimer: see your doctor, in person, for a proper diagnosis; advice over the internet doesn't count)
Oh no...there was 3 kinds of slack when I twisted the driveshaft. :lol:
Originally I thought it may the the transmission, but as I said all symptoms cleared up with the u-joint replacement. Still has the 80 clunk when shifting, but from what I understand that is pretty normal.
Thanks for the medical advice. I got the antibiotics and chest x-ray tuesday. No pneumonia, and on day 4 of the antibiotics I am feeling a bit better. I work in a hospital so the bugs are plentiful. But on the positive side I work AT a hospital so going to the doctor is pretty easy. :D
