<Yeah once I finally crawled under and started twisting it it seemed pretty obvious. But again mine was pretty bad.....or destroyed. At least it was not the transmission. Wish I could have been as lucky with the engine. Another update: got the oil changed today. I ran some motor flush stuff and then changed it out. This is the second time I have done this. Did it originally to try and clear out some of the sludge that Toyota said was causing my pinging/knocking. It has helped quite a bit and rarely knocks anymore.I have been using full synthetic (10/40). Supposedly it can help prevent some of the sludge build-up. I also threw some seafoam in the crank case...because...why not? Replaced the oil filter and even managed to change ot the fuel filter. Really it was not as difficult as it has been made out to be. Maybe the 3FE is easier? Pretty straight forward took about a 1/2 hour. Old one seemed a bit dirty inside. I poked around and pondered the O2 sensor again. Think I may just take it in and have it done. I dont want to mess around with the inevitable (and already) broken bolts. And I really want to get it done by this weekend before I take it on the road. My gas mileage is **** right now, hoping if I get the sensor in it will help a bit. So once I get that in all I will need to do is find a used EGR (hint hint, anyone) that I can try out and see if it makes a difference. I think with all the TLC it has been given the past few weeks it should be much happier. I think I can get a few more miles out of her than the mechanic and Toyota says. I have faith.I will let you all know what changes I notice with the O2 senor. ANd drop me a line if you have an old...but working EGR lying around.Thanks for the info; trying to find the time to check my front shaft, thinking maybe the same deal as you got.
Glad to hear you're feeling better.
Sounds like you're making a lot of progress; I'm gettting just a tad of a stuttering vibration noticed under light load, trying to get under my rig tomorrow to take a look at the driveshafts. My old EGR valve is sitting on a pile of s**** about 1500 miles away, I'm pretty sure it was toast when I replaced it. Maybe someone else out there has a good one. Not sure where the fuel filter is on the early 80's, on my 62 with the 3FE, it is mounted on the PS fender well; very easy to get at, on the later 80's, the fuel filter is below the intake manifold on the DS, a PITA to replace. BTW; when my P401 is acting up, I seem to lose about 1-1 1/2 mpg.
Good luck
. Mine was not giving a CEL code, so I am not exactly sure how they determined it was bad. Of course my CEL was not on when I pulled a "24" off either. Maybe it only comes on when the engine is missing ;p. With everything else that was done I am not sure why my fuel consumption is so high.
I was surprised a couple of years ago that my mpg had dropped almost 3mpg seemingly overnight; I checked everything, and my tire pressure last; it was down only 3psi all around. I aired them back up, above the rec level for the truck, but not the tire; mpg went up almost 3mpg, which really amazed me, that much change from just 3 psi. I think that was a product of the tires; Michelin CrossTerrain SUV; they are very long wearing tires, but have very soft sidewalls; so if the pressure goes down even slightly the tires get wobbly with increase drag IMO. Maybe not quite as critical in a tire with a stiff sidewall for such a small change in psi.
Good luck
I will check it out. I just got 4 new Toyo Ats about 2 months ago, and have assumed Les Schwabb filled them right. Which is stupid of me since Toyota once filled them to 50 PSI (I think the rec for the front is like 29!). Maybe that is why one of my tires was separating. I lucked out there BTW.....good story....... I got the tires from a friend who has a 4runner and liked my stock wheels, so we traded wheels and tires. Which was great because I was going to need new ones soon, and his Toyos were only about 1/4 down. Well a few years later (a few months ago) I went in to have a nail removed and Les Schwabb said they could not replace it because it was coming apart. Even though I did not buy the tires nor did I buy them there they said they would pro-rate it. So I paid $90 for a new tire and as they were putting it on I asked if it was OK to put on 1 tire on a AWD truck. One guy was not sure but the manager said it was saferolleyes
. Long story (too late) short. I confirmed it was not safe through Toyo and ended up getting Les schwab to reluctantly pro rate all 4 tires because of the safety issue and risk of my diff exploding. Saved about $400 on new 31x10.5s.
cheaper doesnt equal enjoyment
Oh, No doubt! I love traveling in the 80. It is comfy, quiet, and tears the pass up while others are creeping along. The signs should read "dangerous conditions ahead, chains or Land Cruisers required"![]()
