'94 front driveshaft-need U-joint part #s
Florida
The bozos at my Yota shop cannot seem to figure it out.
They see part numbers for the snap ring and bearings, but nothing for the spider itself. In addition, the seem to believe there are different part #s for the bearings on the forward and rear joints of the front driveshaft. This makes me think the two spiders are different sizes. The FSM is silent on all of this (I sure wish they showed part numbers).
The rear dirveshaft was easy...there is a kit with all 3 parts so I ordered two of those. The bozo that took my order assumed the two front shaft ujoints would use the same kits so he ordered me a total of 4 kits.
They continue to tell me the spider joints (for the front drive shafts) can only be purchased by purchasing a whole new front driveshaft. :confused:
04371-60070 x2
The rear driveshaft uses 04371-36030 x2.
CDan,
Are the numbers the same for 96? My FSM talks about two different types of rear DS (Type A or Type B) and selecting spider bearings and snaprings based on each. Sometimes that book confuses me.:confused:
Thanks
04371-60070 x2
The above posted numbers apply to all 80 series vehicles.
cruiserdan,
You think its possible some parts like these are intentionaly not linked to the diagrams and computer databases the parts guys use at the counter? I called 4 Yota dealers and NONE of them could find the kit or part # you gave me.
I spoke to this one place for at least an hour. They had several guys try to look it up and failed. Finally the main parts rep swore to me the u-joint kit just wasn't available, all he could do is order a whole front driveshaft.
Then I call back with your part # and whoala, they have 3 kits in stock!
Is this a ploy to sell more expensive parts?
If you ordered them from C-Dan like you should, you wouldn't have any problems and if he feels good, he'll give you a discount!:flipoff2:
cruiserdan,
There is a reason why people here buy there parts from Dan--they get exceptional service, the correct part the first time, and none of this selling you an entire drive shaft when all you need are the joints. And the MUD discount is a deal as well when you consider that you are getting OEM parts...just like our friends at Araco would've wanted it.
-o-
Very cool, I didnt realize he shipped parts.
I picked up my parts and went through all this with parts rep. Sure enough, their database diagrams dont show it as a replaceable part. When he typed in cruiserdan's part #, they showed it covered many vehicles including the LC, but not my '94. All were year 2000 or newer.
So while I curse those turkeys, I still dont see how they were supposed to find it. Very curious indeed. Its either a major documentation error by Toyota, or those ba$tard$ at Toyota Parts HQ are intentionally dropping the over the counter support of these older parts in an attempt to sell a larger assembly.
If cruiserdan or anyone else can explain this I sure would appreciate it. Thanks for all the help fellas.
My dealer up here (where the 80 wasn't even sold) found me the correct ones no questions asked. Dunno how the software works.
I would order from CDan but the man in the brown truck doesn't like me :mad:
Catalog interpretation is an art not often understoood or appreciated. The information is there if one knows how to "process" it. It may look like a trained monkey can do it but that is not the case...........
Yes, and I'm usually the one interpreting for these monkeys. How many other guys get the screen turned toward them so you can point out the part you want. Well, I now go to the assemblies at the bottom first to be sure we're even at the right end of the truck.
