Slee CC bushings on with results.
Oregon
Caster was 2.2 L/R with OME stock height springs, front bumper and winch.
Lifted with 2.5 inch OME heavies with full armor front and back. Front raised 1.75" rear raised 2.5".
Front arms off, Landtanks excellent template with Slee's blue CC bushings on.
New caster is 1.9 L/R.
Very close to spec and drives great.
I think the yellow OME CC bushings are not enough with a 2 plus inch lift.
Very happy, here are a few pics.:beer:
And the lift feels great to. Seems to suck up the bumps better and is smoother:cool:
Landanks template (worth every penny for $10)
All done! Suspension shop charged me $35 to press in the CC's.
I found that the axels move and I used ratchet straps to pull them back to line up the holes.
I had the same experience. I found it was best to let them shift forward, install the control arms at the axle end (the axle will have rotated CCW if you are looking at it from the USPS side) and then you can ratchet it back so the frame bolts line up and simply pivot the axle into place. It was way easier than some of the threads I had read made it out to be... an easy 1 man job, even for a small guy like me.
Agree,
Did it by myself:cool:
I just put the Slee Caster brackets on my rig and had the axles shift on me. It was a huge pain in the ass getting it all back together. Having read your technique now - i should have done it using your method.
Hmmm, anybody used these on a truck with J springs? I've got an empty winch ARB bar on the front. Ben at Slee Off Road was just telling me about these yesterday.
Thanks for posting the pictures.
Bryan
Bryan
They most likely will fall short of correcting caster completely. A few people have used my caster plate with these springs and got the caster to be around 3*. But for a smooth ride you'll probably need to use a DC shaft as well.
Now if you added enough weight to compress the springs and inch then the blue bushings would be fine. You would have similar caster readings as above and the stock shaft should run smooth.
Yes. I never bothered to have my caster measured before or after. I used Rick's template, had the bushings R/R, and bolted the arms back on in my driveway. Took a bit of fanagaling with a pry bar to line up, but an easy one man job. Huge difference in the way the truck handles on the highway now. Very nice over bumps and dips. Tracks straight and true.
Agree,
It's amazing we have guys like Rick (Landtank) and many others who provide us with there technical expertice. I learn some thing new every week about my LC!:beer:
