Is there any cure for this?
What happened here, road salt, curb damage
Yep, and it's fun and easy too! Simply scrape the offending areas against some rocks, preferrably as far from civilization as possible. Those unsightly blemeshes will be removed, and as an added bonus you can usually use the same method to remove the Tupperware stuck to the side of your truck around the wheel openings.
-Spike
rig would be sandblast and powder coat or paint.Ouch! There are wheel repair orginizations. Be prepared to drop about $150.
