I was talking to a mechanic in town today who's quite well regarded by other mechanics in town. He's cutting up some metal for me to help out with a project to make a display for my company as he has a new plasma cutter and I mentioned I was impatiently waiting for a buddy to have time to use a hydrocarbon sniffer on my radiator. He asked why and I told him that there have been some head gasket issues and I've been finding these deposits when I change the coolant for years. Here's what he had to say (BTW, he owns his own shop and has been certified with Jaguar, Mercedes, Subaru and Ford during his career before opening the shop).
He says these grey deposits and the tiny grey/black flakes I see are chemical precipitates from iron and aluminum and mild electrolysis as well as the coolant itself. They are unrelated to any headgasket leak and indeed he says that he's never seen gases from a leaking head gasket cause anything to appear in coolant besides bubbles with one exception. That one exception he saw was a brownish sludge in a cooling system that was strong smelling of combustion.
Over the years, he's worked on a lot of cars and has seen this grey sludge on other models with the same frequency as he has on Toyotas. What happens is that owners typically do not change it out frequently enough and what I am seeing as a competent DIY'er is the flakes that WOULD have become sludge if left long enough. Even many shops do a poor job of changing out coolant - simply dropping the lower hose and refilling in a process that easily leaves 10% of the old fluid in there. As a result, the flakes are not properly rinsed out and get more and more accumulation as they change to sludge.
So, he thinks I'm wasting my time getting it sniffed if I have no symptoms of a HG and that my concern that these flakes were an indicator of a HG issue is unfounded. His feeling on HG issues is that the number one condition that correlates to them is owner neglect of the coolant system - even if it was long ago. Acids and corrosive substances work their way into the edges of the gasket, including crystalline formations that happen when the coolant dries that can microscopically separate the gasket from the sealing surfaces bit by bit. A bit of erosion of the metal sealing rings causes space for coolant, the coolant dries/boils from being too hot in the space (heat soak into the head after shutdown). Then another round of coolant incursion rewets it and the fluid now has a higher content of corrosive substances in there. And so on.
He feels the best defense against HG issues is merely clean and fresh coolant. He also felt the best coolant for the engine was not the latest generation of long life synthetic, organic, blah blah - but Toyota Red.
So, another data point on the topic.
